Classic API Barrier Manager. More...
Modules | |
| Classic Barrier Implementation | |
Files | |
| file | barrier.c |
| RTEMS Barrier Manager Initialization. | |
| file | barriercreate.c |
| RTEMS Create Barrier. | |
| file | barrierdata.c |
| Instantiate Barrier Data. | |
| file | barrierdelete.c |
| RTEMS Delete Barrier. | |
| file | barrierident.c |
| RTEMS Barrier name to Id. | |
| file | barrierrelease.c |
| RTEMS Barrier Release. | |
| file | barriertranslatereturncode.c |
| Translate SuperCore Barrier Status Code to RTEMS Status Code. | |
| file | barrierwait.c |
| RTEMS Barrier Wait. | |
| struct | Barrier_Control |
| This type defines the control block used to manage each barrier. More... | |
| rtems_status_code | rtems_barrier_create (rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id) |
| RTEMS Create Barrier. More... | |
| rtems_status_code | rtems_barrier_ident (rtems_name name, rtems_id *id) |
| RTEMS Barrier name to Id. More... | |
| rtems_status_code | rtems_barrier_delete (rtems_id id) |
| RTEMS Delete Barrier. More... | |
| rtems_status_code | rtems_barrier_wait (rtems_id id, rtems_interval timeout) |
| RTEMS Barrier Wait. More... | |
| rtems_status_code | rtems_barrier_release (rtems_id id, uint32_t *released) |
| RTEMS Barrier Release. More... | |
Inline Implementation from Barrier Manager.
This encapsulates functionality which implements the Classic API Barrier Manager.
This include file contains all the constants and structures associated with the Barrier Manager.
Directives provided are:
This file contains the static inlin implementation of the inlined routines from the Barrier Manager.
| rtems_status_code rtems_barrier_create | ( | rtems_name | name, |
| rtems_attribute | attribute_set, | ||
| uint32_t | maximum_waiters, | ||
| rtems_id * | id | ||
Barrier Manager – Create a Barrier Instance
This routine implements the rtems_barrier_create directive. The barrier will have the name name. The starting count for the barrier is count. The attribute_set determines if the barrier is global or local and the thread queue discipline. It returns the id of the created barrier in ID.
| [in] | name | is the name of this barrier instance. |
| [in] | attribute_set | specifies the attributes of this barrier instance. |
| [in] | maximum_waiters | is the maximum number of threads which will be allowed to concurrently wait at the barrier. |
| [out] | id | will contain the id of this barrier. |
| a | status code indicating success or the reason for failure. |
References _Attributes_Is_barrier_automatic(), _Barrier_Allocate(), _Barrier_Information, _CORE_barrier_Initialize(), _Objects_Allocator_unlock(), _Objects_Open(), Barrier_Control::attribute_set, Barrier_Control::Barrier, CORE_BARRIER_AUTOMATIC_RELEASE, CORE_BARRIER_MANUAL_RELEASE, CORE_barrier_Attributes::discipline, Objects_Control::id, CORE_barrier_Attributes::maximum_count, Barrier_Control::Object, RTEMS_INVALID_ADDRESS, RTEMS_INVALID_NAME, RTEMS_INVALID_NUMBER, rtems_is_name_valid(), RTEMS_SUCCESSFUL, and RTEMS_TOO_MANY.
| rtems_status_code rtems_barrier_delete | ( | rtems_id | id | ) |
This routine implements the rtems_barrier_delete directive. The barrier indicated by id is deleted. The barrier is freed back to the inactive barrier chain.
| [in] | id | indicates the barrier to delete |
References _Barrier_Get(), and _Objects_Allocator_lock().
| rtems_status_code rtems_barrier_ident | ( | rtems_name | name, |
This routine implements the rtems_barrier_ident directive. This directive returns the barrier ID associated with name. If more than one barrier is named name, then the barrier to which the ID belongs is arbitrary. node indicates the extent of the search for the ID of the barrier named name. The search can be limited to a particular node or allowed to encompass all nodes.
| rtems_status_code rtems_barrier_release | ( | rtems_id | id, |
| uint32_t * | released | ||
Barrier Manager – Release Tasks Waitng at a Barrier
This routine implements the rtems_barrier_release directive. It unblocks all of the threads waiting on the barrier associated with id. The number of threads unblocked is returned in released.
| [in] | id | indicates the barrier to wait at. |
| [out] | released | will contain the number of threads unblocked. |
References _Barrier_Get(), and RTEMS_INVALID_ADDRESS.
| rtems_status_code rtems_barrier_wait | ( | rtems_id | id, |
| rtems_interval | timeout | ||
RTEMS Barrier Wait.
This routine implements the rtems_barrier_wait directive. It attempts to wait at the barrier associated with id. The calling task may block waiting for the barrier with an optional timeout of timeout clock ticks.
| [in] | timeout | is the maximum length of time in ticks the calling thread is willing to block. |
