gpio-nxp-pca9535.h
1
9 /*
10  * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
11  *
12  * embedded brains GmbH
13  * Dornierstr. 4
14  * 82178 Puchheim
15  * Germany
16  * <rtems@embedded-brains.de>
17  *
18  * The license and distribution terms for this file may be
19  * found in the file LICENSE in this distribution or at
20  * http://www.rtems.org/license/LICENSE.
21  */
22
23 #ifndef _DEV_I2C_GPIO_NXP_PCA9539_H
24 #define _DEV_I2C_GPIO_NXP_PCA9539_H
25
26 #include <dev/i2c/i2c.h>
27
28 #ifdef __cplusplus
29 extern "C" {
30 #endif /* __cplusplus */
31
42 int i2c_dev_register_gpio_nxp_pca9535(
43  const char *bus_path,
44  const char *dev_path,
45  uint16_t address
46 );
47
48 #define GPIO_NXP_PCA9535_GET_INPUT (I2C_DEV_IO_CONTROL + 0)
49
50 #define GPIO_NXP_PCA9535_GET_OUTPUT (I2C_DEV_IO_CONTROL + 1)
51
52 #define GPIO_NXP_PCA9535_SET_OUTPUT (I2C_DEV_IO_CONTROL + 2)
53
54 #define GPIO_NXP_PCA9535_CLEAR_AND_SET_OUTPUT (I2C_DEV_IO_CONTROL + 3)
55
56 #define GPIO_NXP_PCA9535_GET_POL_INV (I2C_DEV_IO_CONTROL + 4)
57
58 #define GPIO_NXP_PCA9535_SET_POL_INV (I2C_DEV_IO_CONTROL + 5)
59
60 #define GPIO_NXP_PCA9535_GET_CONFIG (I2C_DEV_IO_CONTROL + 6)
61
62 #define GPIO_NXP_PCA9535_SET_CONFIG (I2C_DEV_IO_CONTROL + 7)
63
64 static inline int gpio_nxp_pca9535_get_input(int fd, uint16_t *val)
65 {
66  return ioctl(fd, GPIO_NXP_PCA9535_GET_INPUT, val);
67 }
68
69 static inline int gpio_nxp_pca9535_get_output(int fd, uint16_t *val)
70 {
71  return ioctl(fd, GPIO_NXP_PCA9535_GET_OUTPUT, val);
72 }
73
74 static inline int gpio_nxp_pca9535_set_output(int fd, uint16_t val)
75 {
76  return ioctl(fd, GPIO_NXP_PCA9535_SET_OUTPUT, (void *)(uintptr_t) val);
77 }
78
79 static inline int gpio_nxp_pca9535_clear_and_set_output(
80  int fd,
81  uint16_t clear,
82  uint16_t set
83 )
84 {
85  uint32_t clear_and_set = ((uint32_t) set << 16) | (uint32_t) clear;
86
87  return ioctl(
88  fd,
89  GPIO_NXP_PCA9535_CLEAR_AND_SET_OUTPUT,
90  (void *)(uintptr_t) clear_and_set
91  );
92 }
93
94 static inline int gpio_nxp_pca9535_get_polarity_inversion(
95  int fd,
96  uint16_t *val
97 )
98 {
99  return ioctl(fd, GPIO_NXP_PCA9535_GET_POL_INV, val);
100 }
101
102 static inline int gpio_nxp_pca9535_set_polarity_inversion(int fd, uint16_t val)
103 {
104  return ioctl(fd, GPIO_NXP_PCA9535_SET_POL_INV, (void *)(uintptr_t) val);
105 }
106
107 static inline int gpio_nxp_pca9535_get_config(int fd, uint16_t *val)
108 {
109  return ioctl(fd, GPIO_NXP_PCA9535_GET_CONFIG, val);
110 }
111
112 static inline int gpio_nxp_pca9535_set_config(int fd, uint16_t val)
113 {
114  return ioctl(fd, GPIO_NXP_PCA9535_SET_CONFIG, (void *)(uintptr_t) val);
115 }
116
119 #ifdef __cplusplus
120 }
121 #endif /* __cplusplus */
122
123 #endif /* _DEV_I2C_GPIO_NXP_PCA9539_H */
Inter-Integrated Circuit (I2C) Driver API.
