Inter-Integrated Circuit (I2C) Driver API. More...
#include <linux/i2c.h>
#include <linux/i2c-dev.h>
#include <rtems/seterr.h>
#include <sys/ioctl.h>
#include <sys/stat.h>
Include dependency graph for i2c.h:
struct  i2c_bus
 I2C bus control. More...
struct  i2c_dev
 I2C slave device control. More...
#define I2C_BUS_CLOCK_DEFAULT   100000
 Default I2C bus clock in Hz.
#define I2C_DEV_IO_CONTROL   0x900
 Base number for device IO control commands.
I2C IO Control Commands
#define I2C_BUS_OBTAIN   0x800
 Obtains the bus. More...
#define I2C_BUS_RELEASE   0x801
 Releases the bus. More...
#define I2C_BUS_GET_CONTROL   0x802
 Gets the bus control. More...
#define I2C_BUS_SET_CLOCK   0x803
 Sets the bus clock in Hz. More...
typedef struct i2c_msg i2c_msg
typedef struct i2c_bus i2c_bus
typedef struct i2c_dev i2c_dev
typedef struct i2c_rdwr_ioctl_data i2c_rdwr_ioctl_data
int i2c_bus_init (i2c_bus *bus)
 Initializes a bus control. More...
i2c_busi2c_bus_alloc_and_init (size_t size)
 Allocates a bus control from the heap and initializes it. More...
void i2c_bus_destroy (i2c_bus *bus)
 Destroys a bus control. More...
void i2c_bus_destroy_and_free (i2c_bus *bus)
 Destroys a bus control and frees its memory. More...
int i2c_bus_register (i2c_bus *bus, const char *bus_path)
 Registers a bus control. More...
void i2c_bus_obtain (i2c_bus *bus)
void i2c_bus_release (i2c_bus *bus)
int i2c_bus_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
 Transfers I2C messages. More...
int i2c_dev_init (i2c_dev *dev, const char *bus_path, uint16_t address)
 Initializes a device control. More...
i2c_devi2c_dev_alloc_and_init (size_t size, const char *bus_path, uint16_t address)
 Allocates a device control from the heap and initializes it. More...
void i2c_dev_destroy (i2c_dev *dev)
 Destroys a device control. More...
void i2c_dev_destroy_and_free (i2c_dev *dev)
 Destroys a device control and frees its memory. More...
int i2c_dev_register (i2c_dev *dev, const char *dev_path)
 Registers a device control. More...
