Files | |
| file | bdbuf.c |
| Block device buffer management. | |
| file | bdpart-create.c |
| Manage Partitions of a Disk Device. | |
| file | bdpart-dump.c |
| Prints the Partition Table Partitions with Count Partitions. | |
| file | bdpart-mount.c |
| Block Device Partition Management. | |
| file | bdpart-read.c |
| file | bdpart-register.c |
| file | bdpart-sort.c |
| file | bdpart-write.c |
| file | blkdev-blkstats.c |
| Block Device Statistics Command. | |
| file | blkdev-imfs.c |
| Block Device IMFS. | |
| file | blkdev-ioctl.c |
| Common IO Control Primitive. | |
| file | blkdev-ops.c |
| Block device management. | |
| file | blkdev-print-stats.c |
| Prints the Block Device Statistics. | |
| file | blkdev.c |
| Block Device Management. | |
| file | diskdevs-init.c |
| Block Device Disk Management Initialize. | |
| file | diskdevs.c |
| Block device disk management implementation. | |
| file | flashdisk.c |
| Flash Disk Block Device Implementation. | |
| file | ide_part_table.c |
| Library supporting "MS-DOS-style" Partition Table. | |
| file | media-desc.c |
| Media implementation. | |
| file | media-dev-ident.c |
| file | media-path.c |
| file | media-server.c |
| file | media.c |
| file | nvdisk-sram.c |
| Provide SRAM support for the NV Disk. | |
| file | nvdisk.c |
| Non-Volatile Disk Block Device Implementation. | |
| file | ramdisk-config.c |
| RAM disk block device implementation. | |
| file | ramdisk-driver.c |
| file | ramdisk-init.c |
| file | ramdisk-register.c |
| file | show_bdbuf.c |
| Enable the Monitor to Show bdbuf InformationThis module inspects the bdbuf data structures, assuming they are static, but in fact they are used very dynamically. | |
| file | sparse-disk.c |
| Sparse disk block device implementation. | |
