Device Only File System. More...
#include <rtems/libio_.h>
| struct | devFS_node |
| Per Device Node Control Structure. More... | |
| struct | devFS_data |
| void | devFS_eval_path (rtems_filesystem_eval_path_context_t *ctx) |
| Evaluate Path. | |
| int | devFS_open (rtems_libio_t *iop, const char *pathname, int oflag, mode_t mode) |
| Maps Open Operation to rtems_io_open. More... | |
| int | devFS_close (rtems_libio_t *iop) |
| Maps Close Operation to rtems_io_close. More... | |
| ssize_t | devFS_read (rtems_libio_t *iop, void *buffer, size_t count) |
| Maps Read Operation to rtems_io_read. More... | |
| ssize_t | devFS_write (rtems_libio_t *iop, const void *buffer, size_t count) |
| Writes Operation to rtems_io_write. More... | |
| int | devFS_ioctl (rtems_libio_t *iop, ioctl_command_t command, void *buffer) |
| Maps ioctl Operation to rtems_io_ioctl. More... | |
| int | devFS_stat (const rtems_filesystem_location_info_t *loc, struct stat *buf) |
| Gets the Device File Information. More... | |
| int | devFS_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
| Creates an item in the main device table. More... | |
| int | devFS_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Creates the Main Device Table. More... | |
| void | devFS_Show (void) |
| Retrieves and Prints all the Device Registered in System. More... | |
| const rtems_filesystem_operations_table | devFS_ops |
| The following defines the device-only filesystem operating operations. | |
| const rtems_filesystem_file_handlers_r | devFS_file_handlers |
| The following defines the device-only filesystem operating handlers. | |
This include file contains all constants and structures associated with the 'device-only' filesystem.
