#include <ctype.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include <inttypes.h>#include <rtems.h>#include <rtems/capture-cli.h>#include <rtems/captureimpl.h>#include <rtems/monitor.h>#include <rtems/cpuuse.h>
| struct | rtems_capture_cli_triggers_s |
| #define | RC_UNUSED __attribute__((unused)) |
| #define | RTEMS_CAPTURE_CLI_MAX_LOAD_TASKS (20) |
| #define | RTEMS_CAPTURE_CLI_TRIGGERS_NUM (sizeof (rtems_capture_cli_triggers) / sizeof (rtems_capture_cli_triggers_t)) |
Typedefs | |
| typedef struct rtems_capture_cli_triggers_s | rtems_capture_cli_triggers_t |
| typedef enum rtems_capture_cli_trig_state_e | rtems_capture_cli_trig_state_t |
Enumerations | |
| enum | rtems_capture_cli_trig_state_e { trig_type, trig_to, trig_from_from, trig_from } |
| rtems_status_code | rtems_capture_cli_init (rtems_capture_timestamp timestamp) |
| rtems_capture_cli_init More... | |
| rtems_status_code rtems_capture_cli_init | ( | rtems_capture_timestamp | timestamp | ) |
This function initialises the command line interface to the capture engine.
