timepps.h
1 /*-
2  * ----------------------------------------------------------------------------
3  * "THE BEER-WARE LICENSE" (Revision 42):
4  * <phk@FreeBSD.org> wrote this file. As long as you retain this notice you
5  * can do whatever you want with this stuff. If we meet some day, and you think
6  * this stuff is worth it, you can buy me a beer in return. Poul-Henning Kamp
7  * ----------------------------------------------------------------------------
8  *
9  * Copyright (c) 2011 The FreeBSD Foundation
10  * All rights reserved.
11  *
12  * Portions of this software were developed by Julien Ridoux at the University
13  * of Melbourne under sponsorship from the FreeBSD Foundation.
14  *
15  * $FreeBSD r277406 2015-01-20T03:54:30Z$
16  *
17  * The is a FreeBSD version of the RFC 2783 API for Pulse Per Second
18  * timing interfaces.
19  */
20
21 #ifndef _SYS_TIMEPPS_H_
22 #define _SYS_TIMEPPS_H_
23
24 #include <sys/_ffcounter.h>
25 #include <sys/ioccom.h>
26 #include <sys/time.h>
27
28 #define PPS_API_VERS_1 1
29
30 typedef int pps_handle_t;
31
32 typedef unsigned pps_seq_t;
33
34 typedef struct ntp_fp {
35  unsigned int integral;
36  unsigned int fractional;
37 } ntp_fp_t;
38
39 typedef union pps_timeu {
40  struct timespec tspec;
41  ntp_fp_t ntpfp;
42  unsigned long longpad[3];
43 } pps_timeu_t;
44
45 typedef struct {
46  pps_seq_t assert_sequence; /* assert event seq # */
47  pps_seq_t clear_sequence; /* clear event seq # */
48  pps_timeu_t assert_tu;
49  pps_timeu_t clear_tu;
50  int current_mode; /* current mode bits */
51 } pps_info_t;
52
53 typedef struct {
54  pps_seq_t assert_sequence; /* assert event seq # */
55  pps_seq_t clear_sequence; /* clear event seq # */
56  pps_timeu_t assert_tu;
57  pps_timeu_t clear_tu;
58  ffcounter assert_ffcount; /* ffcounter on assert event */
59  ffcounter clear_ffcount; /* ffcounter on clear event */
60  int current_mode; /* current mode bits */
62
63 #define assert_timestamp assert_tu.tspec
64 #define clear_timestamp clear_tu.tspec
65
66 #define assert_timestamp_ntpfp assert_tu.ntpfp
67 #define clear_timestamp_ntpfp clear_tu.ntpfp
68
69 typedef struct {
70  int api_version; /* API version # */
71  int mode; /* mode bits */
72  pps_timeu_t assert_off_tu;
73  pps_timeu_t clear_off_tu;
74 } pps_params_t;
75
76 #define assert_offset assert_off_tu.tspec
77 #define clear_offset clear_off_tu.tspec
78
79 #define assert_offset_ntpfp assert_off_tu.ntpfp
80 #define clear_offset_ntpfp clear_off_tu.ntpfp
81
82
83 #define PPS_CAPTUREASSERT 0x01
84 #define PPS_CAPTURECLEAR 0x02
85 #define PPS_CAPTUREBOTH 0x03
86
87 #define PPS_OFFSETASSERT 0x10
88 #define PPS_OFFSETCLEAR 0x20
89
90 #define PPS_ECHOASSERT 0x40
91 #define PPS_ECHOCLEAR 0x80
92
93 #define PPS_CANWAIT 0x100
94 #define PPS_CANPOLL 0x200
95
96 #define PPS_TSFMT_TSPEC 0x1000
97 #define PPS_TSFMT_NTPFP 0x2000
98
99 #define PPS_TSCLK_FBCK 0x10000
100 #define PPS_TSCLK_FFWD 0x20000
101 #define PPS_TSCLK_MASK 0x30000
102
103 #define PPS_KC_HARDPPS 0
104 #define PPS_KC_HARDPPS_PLL 1
105 #define PPS_KC_HARDPPS_FLL 2
106
107 struct pps_fetch_args {
108  int tsformat;
109  pps_info_t pps_info_buf;
110  struct timespec timeout;
111 };
112
113 struct pps_fetch_ffc_args {
114  int tsformat;
115  pps_info_ffc_t pps_info_buf_ffc;
116  struct timespec timeout;
117 };
118
119 struct pps_kcbind_args {
120  int kernel_consumer;
121  int edge;
122  int tsformat;
123 };
124
125 #define PPS_IOC_CREATE _IO('1', 1)
126 #define PPS_IOC_DESTROY _IO('1', 2)
127 #define PPS_IOC_SETPARAMS _IOW('1', 3, pps_params_t)
128 #define PPS_IOC_GETPARAMS _IOR('1', 4, pps_params_t)
129 #define PPS_IOC_GETCAP _IOR('1', 5, int)
130 #define PPS_IOC_FETCH _IOWR('1', 6, struct pps_fetch_args)
131 #define PPS_IOC_KCBIND _IOW('1', 7, struct pps_kcbind_args)
132 #define PPS_IOC_FETCH_FFCOUNTER _IOWR('1', 8, struct pps_fetch_ffc_args)
133
134 #ifdef _KERNEL
135
136 struct pps_state {
137  /* Capture information. */
138  struct timehands *capth;
139  struct fftimehands *capffth;
140  unsigned capgen;
141  unsigned capcount;
142
143  /* State information. */
144  pps_params_t ppsparam;
145  pps_info_t ppsinfo;
146  pps_info_ffc_t ppsinfo_ffc;
147  int kcmode;
148  int ppscap;
149  struct timecounter *ppstc;
150  unsigned ppscount[3];
151 };
152
153 void pps_capture(struct pps_state *pps);
154 void pps_event(struct pps_state *pps, int event);
155 void pps_init(struct pps_state *pps);
156 int pps_ioctl(unsigned long cmd, caddr_t data, struct pps_state *pps);
157 void hardpps(struct timespec *tsp, long nsec);
158
159 #else /* !_KERNEL */
160
161 static __inline int
162 time_pps_create(int filedes, pps_handle_t *handle)
163 {
164  int error;
165
166  *handle = -1;
167  error = ioctl(filedes, PPS_IOC_CREATE, 0);
168  if (error < 0)
169  return (-1);
170  *handle = filedes;
171  return (0);
172 }
173
174 static __inline int
175 time_pps_destroy(pps_handle_t handle)
176 {
177  return (ioctl(handle, PPS_IOC_DESTROY, 0));
178 }
179
180 static __inline int
181 time_pps_setparams(pps_handle_t handle, const pps_params_t *ppsparams)
182 {
183  return (ioctl(handle, PPS_IOC_SETPARAMS, ppsparams));
184 }
185
186 static __inline int
187 time_pps_getparams(pps_handle_t handle, pps_params_t *ppsparams)
188 {
189  return (ioctl(handle, PPS_IOC_GETPARAMS, ppsparams));
190 }
191
192 static __inline int
193 time_pps_getcap(pps_handle_t handle, int *mode)
194 {
195  return (ioctl(handle, PPS_IOC_GETCAP, mode));
196 }
197
198 static __inline int
199 time_pps_fetch(pps_handle_t handle, const int tsformat,
200  pps_info_t *ppsinfobuf, const struct timespec *timeout)
201 {
202  int error;
203  struct pps_fetch_args arg;
204
205  arg.tsformat = tsformat;
206  if (timeout == NULL) {
207  arg.timeout.tv_sec = -1;
208  arg.timeout.tv_nsec = -1;
209  } else
210  arg.timeout = *timeout;
211  error = ioctl(handle, PPS_IOC_FETCH, &arg);
212  *ppsinfobuf = arg.pps_info_buf;
213  return (error);
214 }
215
216 static __inline int
217 time_pps_fetch_ffc(pps_handle_t handle, const int tsformat,
218  pps_info_ffc_t *ppsinfobuf, const struct timespec *timeout)
219 {
220  struct pps_fetch_ffc_args arg;
221  int error;
222
223  arg.tsformat = tsformat;
224  if (timeout == NULL) {
225  arg.timeout.tv_sec = -1;
226  arg.timeout.tv_nsec = -1;
227  } else {
228  arg.timeout = *timeout;
229  }
230  error = ioctl(handle, PPS_IOC_FETCH_FFCOUNTER, &arg);
231  *ppsinfobuf = arg.pps_info_buf_ffc;
232  return (error);
233 }
234
235 static __inline int
236 time_pps_kcbind(pps_handle_t handle, const int kernel_consumer,
237  const int edge, const int tsformat)
238 {
239  struct pps_kcbind_args arg;
240
241  arg.kernel_consumer = kernel_consumer;
242  arg.edge = edge;
243  arg.tsformat = tsformat;
244  return (ioctl(handle, PPS_IOC_KCBIND, &arg));
245 }
246
247 #endif /* KERNEL */
248
249 #endif /* !_SYS_TIMEPPS_H_ */
Definition: timepps.h:54
Definition: timepps.h:40
Definition: timepps.h:46
Definition: timetc.h:37
Definition: kern_tc.c:113
Definition: timepps.h:120
Definition: timepps.h:70
Definition: timepps.h:35
Definition: timepps.h:108
Definition: timepps.h:114
