Macros | Typedefs | Functions
ioccom.h File Reference
#include <sys/types.h>
#include <stdint.h>
#include <sys/cdefs.h>
Include dependency graph for ioccom.h:
#define IOCPARM_SHIFT   13 /* number of bits for ioctl size */
#define IOCPARM_MASK   ((1 << IOCPARM_SHIFT) - 1) /* parameter length mask */
#define IOCPARM_LEN(x)   (((x) >> 16) & IOCPARM_MASK)
#define IOCBASECMD(x)   ((x) & ~(IOCPARM_MASK << 16))
#define IOCGROUP(x)   (((x) >> 8) & 0xff)
#define IOCPARM_MAX   (1 << IOCPARM_SHIFT) /* max size of ioctl */
#define IOC_VOID   0x20000000 /* no parameters */
#define IOC_OUT   0x40000000 /* copy out parameters */
#define IOC_IN   0x80000000 /* copy in parameters */
#define IOC_INOUT   (IOC_IN|IOC_OUT)
#define IOC_DIRMASK   (IOC_VOID|IOC_OUT|IOC_IN)
#define _IOC(inout, group, num, len)
#define _IO(g, n)   _IOC(IOC_VOID, (g), (n), 0)
#define _IOWINT(g, n)   _IOC(IOC_VOID, (g), (n), sizeof(int))
#define _IOR(g, n, t)   _IOC(IOC_OUT, (g), (n), sizeof(t))
#define _IOW(g, n, t)   _IOC(IOC_IN, (g), (n), sizeof(t))
#define _IOWR(g, n, t)   _IOC(IOC_INOUT, (g), (n), sizeof(t))
#define RTEMS_IO_GET_ATTRIBUTES   1
#define RTEMS_IO_SET_ATTRIBUTES   2
#define RTEMS_IO_TCDRAIN   3
#define RTEMS_IO_RCVWAKEUP   4
#define RTEMS_IO_SNDWAKEUP   5
#define RTEMS_IO_TCFLUSH   6
#define FIOCLEX   _IO('f', 1) /* set close on exec on fd */
#define FIONCLEX   _IO('f', 2) /* remove close on exec */
#define FIONREAD   _IOR('f', 127, int) /* get # bytes to read */
#define FIONBIO   _IOW('f', 126, int) /* set/clear non-blocking i/o */
#define FIOASYNC   _IOW('f', 125, int) /* set/clear async i/o */
#define FIOSETOWN   _IOW('f', 124, int) /* set owner */
#define FIOGETOWN   _IOR('f', 123, int) /* get owner */
typedef uint32_t ioctl_command_t
__BEGIN_DECLS int ioctl (int, ioctl_command_t,...)
◆ _IOC
#define _IOC (   inout,
  group,
  num,
  len
Value:
((ioctl_command_t) \
((ioctl_command_t) (inout) \
| (((ioctl_command_t) (len) & IOCPARM_MASK) << 16) \
| ((ioctl_command_t) (group) << 8) \
| (ioctl_command_t) (num)))
