POSIX Termios Implementation for RTEMS Console Device Driver. More...
#include <sys/types.h>
struct | termios |
#define | NCCS 19 |
#define | _POSIX_VDISABLE 0 |
This value is used to disable processing of a member of c_cc in the struct termios. | |
#define | VINTR 0 |
#define | VQUIT 1 |
#define | VERASE 2 |
#define | VKILL 3 |
#define | VEOF 4 |
#define | VTIME 5 |
#define | VMIN 6 |
#define | VSWTC 7 |
#define | VSTART 8 |
#define | VSTOP 9 |
#define | VSUSP 10 |
#define | VEOL 11 |
#define | VREPRINT 12 |
#define | VDISCARD 13 |
#define | VWERASE 14 |
#define | VLNEXT 15 |
#define | VEOL2 16 |
#define | IGNBRK 0000001 |
#define | BRKINT 0000002 |
#define | IGNPAR 0000004 |
#define | PARMRK 0000010 |
#define | INPCK 0000020 |
#define | ISTRIP 0000040 |
#define | INLCR 0000100 |
#define | IGNCR 0000200 |
#define | ICRNL 0000400 |
#define | IUCLC 0001000 |
#define | IXON 0002000 |
#define | IXANY 0004000 |
#define | IXOFF 0010000 |
#define | IMAXBEL 0020000 |
#define | OPOST 0000001 |
#define | OLCUC 0000002 |
#define | ONLCR 0000004 |
#define | OCRNL 0000010 |
#define | ONOCR 0000020 |
#define | ONLRET 0000040 |
#define | OFILL 0000100 |
#define | OFDEL 0000200 |
#define | NLDLY 0000400 |
#define | NL0 0000000 |
#define | NL1 0000400 |
#define | CRDLY 0003000 |
#define | CR0 0000000 |
#define | CR1 0001000 |
#define | CR2 0002000 |
#define | CR3 0003000 |
#define | TABDLY 0014000 |
#define | TAB0 0000000 |
#define | TAB1 0004000 |
#define | TAB2 0010000 |
#define | TAB3 0014000 |
#define | XTABS 0014000 |
#define | BSDLY 0020000 |
#define | BS0 0000000 |
#define | BS1 0020000 |
#define | VTDLY 0040000 |
#define | VT0 0000000 |
#define | VT1 0040000 |
#define | FFDLY 0100000 |
#define | FF0 0000000 |
#define | FF1 0100000 |
#define | CBAUD 0010017 |
#define | B0 0000000 /* hang up */ |
#define | B50 0000001 |
#define | B75 0000002 |
#define | B110 0000003 |
#define | B134 0000004 |
#define | B150 0000005 |
#define | B200 0000006 |
#define | B300 0000007 |
#define | B600 0000010 |
#define | B1200 0000011 |
#define | B1800 0000012 |
#define | B2400 0000013 |
#define | B4800 0000014 |
#define | B9600 0000015 |
#define | B19200 0000016 |
#define | B38400 0000017 |
#define | EXTA B19200 |
#define | EXTB B38400 |
#define | CSIZE 0000060 |
#define | CS5 0000000 |
#define | CS6 0000020 |
#define | CS7 0000040 |
#define | CS8 0000060 |
#define | CSTOPB 0000100 |
#define | CREAD 0000200 |
#define | PARENB 0000400 |
#define | PARODD 0001000 |
#define | HUPCL 0002000 |
#define | CLOCAL 0004000 |
#define | CBAUDEX 0010000 |
#define | B57600 0010001 |
#define | B115200 0010002 |
#define | B230400 0010003 |
#define | B460800 0010004 |
#define | CIBAUD 002003600000 /* input baud rate (not used) */ |
#define | CRTSCTS 020000000000 /* flow control */ |
#define | RTEMS_TERMIOS_NUMBER_BAUD_RATES 20 |
#define | ISIG 0000001 |
#define | ICANON 0000002 |
#define | XCASE 0000004 |
#define | ECHO 0000010 |
#define | ECHOE 0000020 |
#define | ECHOK 0000040 |
#define | ECHONL 0000100 |
#define | NOFLSH 0000200 |
#define | TOSTOP 0000400 |
#define | ECHOCTL 0001000 |
#define | ECHOPRT 0002000 |
#define | ECHOKE 0004000 |
#define | FLUSHO 0010000 |
#define | PENDIN 0040000 |
#define | IEXTEN 0100000 |
#define | TCOOFF 0 |
#define | TCOON 1 |
#define | TCIOFF 2 |
#define | TCION 3 |
#define | TCIFLUSH 0 |
#define | TCOFLUSH 1 |
#define | TCIOFLUSH 2 |
#define | TCSANOW 0 |
#define | TCSADRAIN 1 |
#define | TCSAFLUSH 2 |
typedef unsigned char | cc_t |
POSIX Termios Implementation. More... | |
typedef unsigned int | speed_t |
typedef unsigned int | tcflag_t |
int | tcdrain (int) |
int | tcflow (int, int) |
int | tcflush (int, int) |
int | tcgetattr (int, struct termios *) |
int | tcsetattr (int, int, struct termios *) |
pid_t | tcgetprgrp (int) |
int | tcsetprgrp (int, pid_t) |
int | tcsendbreak (int, int) |
speed_t | cfgetospeed (const struct termios *tp) |
int | cfsetospeed (struct termios *tp, speed_t speed) |
speed_t | cfgetispeed (const struct termios *tp) |
int | cfsetispeed (struct termios *tp, speed_t speed) |
void | cfmakeraw (struct termios *tp) |
int | cfsetspeed (struct termios *tp, speed_t speed) |
The Open Group Base Specifications Issue 6 IEEE Std 1003.1, 2004 Edition Chapter 11, General Terminal Interface
