The compressed file. More...
#include <rtl-obj-comp.h>
Data Fields | |
| rtems_rtl_obj_cache_t * | cache |
| The cache provides the input buffer. More... | |
| int | fd |
| The file descriptor. More... | |
| int | compression |
| The type of compression. More... | |
| off_t | offset |
| The base offset of the buffer. More... | |
| size_t | size |
| The size of the output buffer. More... | |
| size_t | level |
| The amount of data in the buffer. More... | |
| uint8_t * | buffer |
| The buffer. | |
| uint32_t | read |
| The amount of data read. More... | |
| rtems_rtl_obj_cache_t* rtems_rtl_obj_cpmp_s::cache |
Referenced by rtems_rtl_obj_comp_close(), and rtems_rtl_obj_comp_set().
| int rtems_rtl_obj_cpmp_s::compression |
| int rtems_rtl_obj_cpmp_s::fd |
| size_t rtems_rtl_obj_cpmp_s::level |
Referenced by rtems_rtl_obj_comp_set().
| off_t rtems_rtl_obj_cpmp_s::offset |
| uint32_t rtems_rtl_obj_cpmp_s::read |
| size_t rtems_rtl_obj_cpmp_s::size |
