JFFS2 flash device control. More...
#include <jffs2.h>
Collaboration diagram for rtems_jffs2_flash_control:
Collaboration graph
[legend]
uint32_t block_size
 The size in bytes of the erasable unit of the flash device.
uint32_t flash_size
 The size in bytes of the flash device. More...
rtems_jffs2_flash_read read
 Read from flash operation.
rtems_jffs2_flash_write write
 Write to flash operation.
rtems_jffs2_flash_erase erase
 Flash erase operation.
rtems_jffs2_flash_destroy destroy
 Flash destroy operation. More...
dev_t device_identifier
 The device identifier of the flash device. More...
Field Documentation
◆ destroy
rtems_jffs2_flash_destroy rtems_jffs2_flash_control::destroy
This operation is optional and the pointer may be NULL.
◆ device_identifier
dev_t rtems_jffs2_flash_control::device_identifier
It is used in combination with the inode number to uniquely identify a file system node in the system.
◆ flash_size
uint32_t rtems_jffs2_flash_control::flash_size
It must be an integral multiple of the block size. The flash device must have at least five blocks.
