Capture control structure for a group of tasks. More...
#include <capture.h>
Data Fields | |
rtems_name | name |
rtems_id | id |
uint32_t | flags |
uint32_t | to_triggers |
uint32_t | from_triggers |
uint32_t | by_triggers |
uint32_t | by_valid |
rtems_capture_from_t | by [RTEMS_CAPTURE_TRIGGER_TASKS] |
struct rtems_capture_control_s * | next |
RTEMS control holds the trigger and watch configuration for a group of tasks with the same name. The flags hold global control flags.
The to_triggers fields holds triggers TO this task. The from_triggers holds triggers from this task. The by_triggers is an OR or triggers which are caused BY the task listed TO this task. The by_valid flag which entries in by are valid.
