FAT file system format request parameters. More...
#include <dosfs.h>
Data Fields | |
const char * | OEMName |
OEM name string or NULL. | |
const char * | VolLabel |
Volume label string or NULL. | |
uint32_t | sectors_per_cluster |
Sectors per cluster hint. More... | |
uint32_t | fat_num |
Number of FATs hint. More... | |
uint32_t | files_per_root_dir |
Minimum files in root directory for FAT12 and FAT16. More... | |
uint8_t | media |
Media code. More... | |
bool | quick_format |
Quick format. More... | |
bool | skip_alignment |
Do not align FAT, data cluster, and root directory to a cluster boundary. | |
bool | sync_device |
Synchronize device after write operations. | |
int | info_level |
The amount of info to output. | |
uint32_t msdos_format_request_param_t::fat_num |
Use 0 as default value.
uint32_t msdos_format_request_param_t::files_per_root_dir |
The format procedure may choose a greater value. Use 0 as default value.
uint8_t msdos_format_request_param_t::media |
Media code.
Use 0 as default value. The default media code is 0xf8.
bool msdos_format_request_param_t::quick_format |
Quick format.
If set to true, then do not clear data sectors to zero.
uint32_t msdos_format_request_param_t::sectors_per_cluster |
The format procedure may choose another value. Use 0 as default value.
