Creates bit allocator for blocks in the group simpler. More...
#include <rtems-rfs-group.h>
Data Fields | |
| rtems_rfs_buffer_block | base |
| Base block number. | |
| size_t | size |
| The number of blocks in the group. More... | |
| rtems_rfs_bitmap_control | block_bitmap |
| The block bitmap control. | |
| rtems_rfs_buffer_handle | block_bitmap_buffer |
| The handle to the block bitmap buffer. | |
| rtems_rfs_bitmap_control | inode_bitmap |
| The inode bitmap control. | |
| rtems_rfs_buffer_handle | inode_bitmap_buffer |
| The handle to the inode bitmap buffer. | |
A group is a selection of blocks on the disk. Typically the number of blocks in a group is determined by the number of bits a block holds. This makes the bit allocator for blocks in the group simpler plus is allows a simple way to localise access to files and directories.
| size_t _rtems_rfs_group::size |
Groups may be different sizes.
