_rtems_rfs_format_config Struct Reference
RFS File System Configuration data used to format the file system. More...
#include <rtems-rfs-format.h>
size_t block_size
 The size of a block.
size_t group_blocks
 The number of blocks in a group.
size_t group_inodes
 The number of inodes in a group.
int inode_overhead
 The percentage overhead allocated to inodes.
size_t max_name_length
 The maximum length of a name.
bool initialise_inodes
 Initialise the inode tables to all ones.
bool verbose
 Is the format verbose.
For default values leave the field set to 0.
