ASR_Information Struct Reference
The following defines the control structure used to manage signals. More...
#include <asr.h>
Collaboration diagram for ASR_Information:
Collaboration graph
[legend]
bool is_enabled
 This field indicates if are ASRs enabled currently. More...
rtems_asr_entry handler
 This field indicates if address of the signal handler function. More...
Modes_Control mode_set
 This field indicates if the task mode the signal will run with. More...
rtems_signal_set signals_posted
 This field indicates the signal set that is posted. More...
rtems_signal_set signals_pending
 This field indicates the signal set that is pending. More...
uint32_t nest_level
 This field indicates if nest level of signals being processed.
ISR_lock_Control Lock
 Lock to protect this structure.
Each thread has a copy of this record.
Field Documentation
◆ handler
rtems_asr_entry ASR_Information::handler
Referenced by _ASR_Initialize(), and rtems_signal_catch().
◆ is_enabled
bool ASR_Information::is_enabled
Referenced by _ASR_Initialize().
◆ mode_set
Modes_Control ASR_Information::mode_set
◆ signals_pending
rtems_signal_set ASR_Information::signals_pending
Referenced by _ASR_Initialize(), and _ASR_Swap_signals().
◆ signals_posted
rtems_signal_set ASR_Information::signals_posted
Referenced by _ASR_Are_signals_pending(), _ASR_Initialize(), and _ASR_Swap_signals().
