The control structure which defines the points at which an API can add an extension to the system initialization thread. More...
#include <apiext.h>
Data Fields | |
| Chain_Node | Node |
| This field allows this structure to be used with the Chain Handler. More... | |
| API_extensions_Postdriver_hook | postdriver_hook |
| This field is the callout invoked during RTEMS initialization after RTEMS data structures and device driver initialization has occurred but before multitasking is initiated. More... | |
| Chain_Node API_extensions_Control::Node |
Referenced by _API_extensions_Add().
| API_extensions_Postdriver_hook API_extensions_Control::postdriver_hook |
Referenced by _API_extensions_Run_postdriver().
