RTEMS RFS Directory Access Routines. More...
#include <inttypes.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <rtems/rfs/rtems-rfs-dir.h>
#include <rtems/rfs/rtems-rfs-link.h>
#include "rtems-rfs-rtems.h"
Include dependency graph for rtems-rfs-rtems-dir.c:
const rtems_filesystem_file_handlers_r rtems_rfs_rtems_dir_handlers
 The handlers. More...
Variable Documentation
◆ rtems_rfs_rtems_dir_handlers
Initial value:
.open_h = rtems_rfs_rtems_dir_open,
.close_h = rtems_rfs_rtems_dir_close,
.read_h = rtems_rfs_rtems_dir_read,
.fdatasync_h = rtems_rfs_rtems_fdatasync,
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:21
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:32
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:31
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:32
off_t rtems_filesystem_default_lseek_directory(rtems_libio_t *iop, off_t offset, int whence)
An offset 0 with a whence of SEEK_SET will perform a directory rewind operation.
Definition: default_lseek_directory.c:28
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:32
int rtems_filesystem_default_ftruncate_directory(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate_directory.c:29
int rtems_rfs_rtems_fstat(const rtems_filesystem_location_info_t *pathloc, struct stat *buf)
The following routine does a stat on a node.
Definition: rtems-rfs-rtems.c:438
int rtems_rfs_rtems_fdatasync(rtems_libio_t *iop)
The following routine does a sync on an inode node.
Definition: rtems-rfs-rtems.c:615
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:21
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:23
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:23
The handlers.
