Typedefs | Functions
RTEMS File System Mutex. More...
#include <rtems/rfs/rtems-rfs-trace.h>
Include dependency graph for rtems-rfs-mutex.h:
typedef uint32_t rtems_rfs_mutex
 RFS Mutex type.
int rtems_rfs_mutex_create (rtems_rfs_mutex *mutex)
 Create the mutex. More...
int rtems_rfs_mutex_destroy (rtems_rfs_mutex *mutex)
 Destroy the mutex. More...
It may be suprising we abstract this for the RTEMS file system but this code is designed to be run on host operating systems.
◆ rtems_rfs_mutex_create()
int rtems_rfs_mutex_create ( rtems_rfs_mutex mutex)
Create the mutex.
Parameters
[in]mutexis pointer to the mutex handle returned to the caller.
Return values
0Successful operation.
EIOAn error occurred.
References rtems_build_name, rtems_rfs_trace(), rtems_semaphore_create(), and RTEMS_SUCCESSFUL.
◆ rtems_rfs_mutex_destroy()
int rtems_rfs_mutex_destroy ( rtems_rfs_mutex mutex)
Destroy the mutex.
Parameters
[in]mutexReference to the mutex handle returned to the caller.
Return values
References rtems_rfs_trace(), rtems_semaphore_delete(), and RTEMS_SUCCESSFUL.
Referenced by rtems_rfs_rtems_shutdown().
