reboot.h
1 /*
2  * Copyright (c) 1982, 1986, 1988, 1993, 1994
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. All advertising materials mentioning features or use of this software
14  * must display the following acknowledgement:
15  * This product includes software developed by the University of
16  * California, Berkeley and its contributors.
17  * 4. Neither the name of the University nor the names of its contributors
18  * may be used to endorse or promote products derived from this software
19  * without specific prior written permission.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31  * SUCH DAMAGE.
32  *
33  * @(#)reboot.h 8.3 (Berkeley) 12/13/94
34  */
35
36 #ifndef _SYS_REBOOT_H_
37 #define _SYS_REBOOT_H_
38
39 /*
40  * Arguments to reboot system call. These are passed to
41  * the boot program and on to init.
42  */
43 #define RB_AUTOBOOT 0 /* flags for system auto-booting itself */
44
45 #define RB_ASKNAME 0x001 /* ask for file name to reboot from */
46 #define RB_SINGLE 0x002 /* reboot to single user only */
47 #define RB_NOSYNC 0x004 /* dont sync before reboot */
48 #define RB_HALT 0x008 /* don't reboot, just halt */
49 #define RB_INITNAME 0x010 /* name given for /etc/init (unused) */
50 #define RB_DFLTROOT 0x020 /* use compiled-in rootdev */
51 #define RB_KDB 0x040 /* give control to kernel debugger */
52 #define RB_RDONLY 0x080 /* mount root fs read-only */
53 #define RB_DUMP 0x100 /* dump kernel memory before reboot */
54 #define RB_MINIROOT 0x200 /* mini-root present in memory at boot time */
55 #define RB_CONFIG 0x400 /* invoke user configuration routing */
56 #define RB_VERBOSE 0x800 /* print all potentially useful info */
57 #define RB_SERIAL 0x1000 /* user serial port as console */
58 #define RB_CDROM 0x2000 /* use cdrom as root */
59 #define RB_POWEROFF 0x4000 /* if you can, turn the power off */
60 #define RB_GDB 0x8000 /* use GDB remote debugger instead of DDB */
61 #define RB_MUTE 0x10000 /* Come up with the console muted */
62 #define RB_SELFTEST 0x20000 /* don't boot to normal operation, do selftest */
63
64 #define RB_BOOTINFO 0x80000000 /* have `struct bootinfo *' arg */
65
66 /*
67  * Constants for converting boot-style device number to type,
68  * adaptor (uba, mba, etc), unit number and partition number.
69  * Type (== major device number) is in the low byte
70  * for backward compatibility. Except for that of the "magic
71  * number", each mask applies to the shifted value.
72  * Format:
73  * (4) (4) (4) (4) (8) (8)
74  * --------------------------------
75  * |MA | AD| CT| UN| PART | TYPE |
76  * --------------------------------
77  */
78 #define B_ADAPTORSHIFT 24
79 #define B_ADAPTORMASK 0x0f
80 #define B_ADAPTOR(val) (((val) >> B_ADAPTORSHIFT) & B_ADAPTORMASK)
81 #define B_CONTROLLERSHIFT 20
82 #define B_CONTROLLERMASK 0xf
83 #define B_CONTROLLER(val) (((val)>>B_CONTROLLERSHIFT) & B_CONTROLLERMASK)
84 #define B_SLICESHIFT 20
85 #define B_SLICEMASK 0xff
86 #define B_SLICE(val) (((val)>>B_SLICESHIFT) & B_SLICEMASK)
87 #define B_UNITSHIFT 16
88 #define B_UNITMASK 0xf
89 #define B_UNIT(val) (((val) >> B_UNITSHIFT) & B_UNITMASK)
90 #define B_PARTITIONSHIFT 8
91 #define B_PARTITIONMASK 0xff
92 #define B_PARTITION(val) (((val) >> B_PARTITIONSHIFT) & B_PARTITIONMASK)
93 #define B_TYPESHIFT 0
94 #define B_TYPEMASK 0xff
95 #define B_TYPE(val) (((val) >> B_TYPESHIFT) & B_TYPEMASK)
96
97 #define B_MAGICMASK 0xf0000000
98 #define B_DEVMAGIC 0xa0000000
99
100 #define MAKEBOOTDEV(type, adaptor, controller, unit, partition) \
101  (((type) << B_TYPESHIFT) | ((adaptor) << B_ADAPTORSHIFT) | \
102  ((controller) << B_CONTROLLERSHIFT) | ((unit) << B_UNITSHIFT) | \
103  ((partition) << B_PARTITIONSHIFT) | B_DEVMAGIC)
104
105 #endif
