| #define | RB_AUTOBOOT 0 /* flags for system auto-booting itself */ |
| #define | RB_ASKNAME 0x001 /* ask for file name to reboot from */ |
| #define | RB_SINGLE 0x002 /* reboot to single user only */ |
| #define | RB_NOSYNC 0x004 /* dont sync before reboot */ |
| #define | RB_HALT 0x008 /* don't reboot, just halt */ |
| #define | RB_INITNAME 0x010 /* name given for /etc/init (unused) */ |
| #define | RB_DFLTROOT 0x020 /* use compiled-in rootdev */ |
| #define | RB_KDB 0x040 /* give control to kernel debugger */ |
| #define | RB_RDONLY 0x080 /* mount root fs read-only */ |
| #define | RB_DUMP 0x100 /* dump kernel memory before reboot */ |
| #define | RB_MINIROOT 0x200 /* mini-root present in memory at boot time */ |
| #define | RB_CONFIG 0x400 /* invoke user configuration routing */ |
| #define | RB_VERBOSE 0x800 /* print all potentially useful info */ |
| #define | RB_SERIAL 0x1000 /* user serial port as console */ |
| #define | RB_CDROM 0x2000 /* use cdrom as root */ |
| #define | RB_POWEROFF 0x4000 /* if you can, turn the power off */ |
| #define | RB_GDB 0x8000 /* use GDB remote debugger instead of DDB */ |
| #define | RB_MUTE 0x10000 /* Come up with the console muted */ |
| #define | RB_SELFTEST 0x20000 /* don't boot to normal operation, do selftest */ |
| #define | RB_BOOTINFO 0x80000000 /* have `struct bootinfo *' arg */ |
| #define | B_ADAPTORSHIFT 24 |
| #define | B_ADAPTORMASK 0x0f |
| #define | B_ADAPTOR(val) (((val) >> B_ADAPTORSHIFT) & B_ADAPTORMASK) |
| #define | B_CONTROLLERSHIFT 20 |
| #define | B_CONTROLLERMASK 0xf |
| #define | B_CONTROLLER(val) (((val)>>B_CONTROLLERSHIFT) & B_CONTROLLERMASK) |
| #define | B_SLICESHIFT 20 |
| #define | B_SLICEMASK 0xff |
| #define | B_SLICE(val) (((val)>>B_SLICESHIFT) & B_SLICEMASK) |
| #define | B_UNITSHIFT 16 |
| #define | B_UNITMASK 0xf |
| #define | B_UNIT(val) (((val) >> B_UNITSHIFT) & B_UNITMASK) |
| #define | B_PARTITIONSHIFT 8 |
| #define | B_PARTITIONMASK 0xff |
| #define | B_PARTITION(val) (((val) >> B_PARTITIONSHIFT) & B_PARTITIONMASK) |
| #define | B_TYPESHIFT 0 |
| #define | B_TYPEMASK 0xff |
| #define | B_TYPE(val) (((val) >> B_TYPESHIFT) & B_TYPEMASK) |
| #define | B_MAGICMASK 0xf0000000 |
| #define | B_DEVMAGIC 0xa0000000 |
| #define | MAKEBOOTDEV(type, adaptor, controller, unit, partition) |
