POSIX Signals Support. More...
#include <rtems/posix/psignal.h>
#include <rtems/posix/pthread.h>
#include <rtems/posix/sigset.h>
#include <rtems/score/apiext.h>
#include <rtems/score/isrlock.h>
void | _POSIX_signals_Manager_Initialization (void) |
POSIX signals manager initialization. | |
void | _POSIX_signals_Action_handler (Thread_Control *executing, Thread_Action *action, Per_CPU_Control *cpu, ISR_Level level) |
bool | _POSIX_signals_Unblock_thread (Thread_Control *the_thread, int signo, siginfo_t *info) |
Unlock POSIX signals thread. | |
bool | _POSIX_signals_Check_signal (POSIX_API_Control *api, int signo, bool is_global) |
Check POSIX signal. | |
bool | _POSIX_signals_Clear_signals (POSIX_API_Control *api, int signo, siginfo_t *info, bool is_global, bool check_blocked, bool do_signals_acquire_release) |
Clear POSIX signals. | |
int | killinfo (pid_t pid, int sig, const union sigval *value) |
void | _POSIX_signals_Set_process_signals (sigset_t mask) |
Set POSIX process signals. | |
void | _POSIX_signals_Clear_process_signals (int signo) |
void | _POSIX_signals_Abnormal_termination_handler (int signo) |
sigset_t | _POSIX_signals_Pending |
const struct sigaction | _POSIX_signals_Default_vectors [SIG_ARRAY_MAX] |
struct sigaction | _POSIX_signals_Vectors [SIG_ARRAY_MAX] |
Thread_queue_Control | _POSIX_signals_Wait_queue |
Chain_Control | _POSIX_signals_Inactive_siginfo |
Chain_Control | _POSIX_signals_Siginfo [SIG_ARRAY_MAX] |
This include file defines internal information about POSIX signals.
