pci_bus.h
1 /* PCI bus driver Interface.
2  *
3  * COPYRIGHT (c) 2008 Cobham Gaisler AB.
4  *
5  * The license and distribution terms for this file may be
6  * found in the file LICENSE in this distribution or at
7  * http://www.rtems.org/license/LICENSE.
8  *
9  */
10
11 /* General part of drvmgr PCI Bus driver. The driver is typically
12  * initialized from the PCI host driver separating the host
13  * driver from the common parts in PCI drivers.
14  * The PCI library must be initialized before starting the
15  * PCI bus driver. The PCI library have set up BARs and
16  * assigned system IRQs for targets.
17  * This PCI bus driver rely on the PCI library (pci.c) for
18  * interrupt registeration (pci_interrupt_register) and PCI
19  * target set up.
20  */
21
22 #ifndef __PCI_BUS_H__
23 #define __PCI_BUS_H__
24
25 #include <drvmgr/drvmgr.h>
26 #include <pci.h>
27 #include <pci/access.h>
28
29 #ifdef __cplusplus
30 extern "C" {
31 #endif
32
33 /* PCI Driver ID generation (VENDOR: 16-bit, DEVICE: 16-bit) */
34 #define DRIVER_PCI_ID(vendor, device) \
35  DRIVER_ID(DRVMGR_BUS_TYPE_PCI, \
36  ((((vendor) & 0xffff) << 16) | ((device) & 0xffff)))
37
38 /* PCI Driver ID generation (CLASS: 24-bit) */
39 #define DRIVER_PCI_CLASS(class) \
40  DRIVER_ID(DRVMGR_BUS_TYPE_PCI, ((1 << 32) | ((class) & 0xffffff)))
41
42 /* PCI driver IDs (DRIVER_PCI_VENDOR_DEVICE or DRIVER_PCI_CLASS_NAME) */
43 #define DRIVER_PCI_GAISLER_RASTAIO_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_IO)
44 #define DRIVER_PCI_GAISLER_RASTATMTC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_TMTC)
45 #define DRIVER_PCI_GAISLER_GR701_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_701)
46 #define DRIVER_PCI_GAISLER_RASTAADCDAC_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_ADCDAC)
47 #define DRIVER_PCI_GAISLER_TMTC_1553_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_TMTC_1553)
48 #define DRIVER_PCI_GAISLER_RASTA_SPW_ROUTER_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_RASTA_SPW_RTR)
49 #define DRIVER_PCI_GAISLER_LEON4_N2X_ID DRIVER_PCI_ID(PCIID_VENDOR_GAISLER, PCIID_DEVICE_GR_LEON4_N2X)
50
51 struct pci_dev_id {
52  uint16_t vendor;
53  uint16_t device;
54  uint16_t subvendor;
55  uint16_t subdevice;
56  uint32_t class; /* 24 lower bits */
57 };
58
59 struct pci_dev_id_match {
60  uint16_t vendor;
61  uint16_t device;
62  uint16_t subvendor;
63  uint16_t subdevice;
64  uint32_t class; /* 24 lower bits */
65  uint32_t class_mask; /* 24 lower bits */
66 };
67 #define PCIID_DEVVEND(vendor, device) \
68  {vendor, device, PCI_ID_ANY, PCI_ID_ANY, 0, 0}
69 #define PCIID_END_TABLE {0, 0, 0, 0, 0, 0}
70
71 enum {
72  /* A Device has up to 6 BARs and an optional ROM BAR */
73  PCIDEV_RES_BAR1 = 0,
74  PCIDEV_RES_BAR2 = 1,
75  PCIDEV_RES_BAR3 = 2,
76  PCIDEV_RES_BAR4 = 3,
77  PCIDEV_RES_BAR5 = 4,
78  PCIDEV_RES_BAR6 = 5,
79  PCIDEV_RES_ROM = 6,
80 };
81 /* Maximum Number of Resources of a device */
82 #define PCIDEV_RES_CNT (PCIDEV_RES_ROM + 1)
83
84 /* IO, MEMIO or MEM resource. Can be BAR, ROM or Bridge Window */
85 struct pcibus_res {
86  uint32_t address; /* Base Address, CPU accessible */
87  uint32_t size; /* 0=Unimplemented, 0!=Resource Size */
88  struct pci_res *res; /* PCI-layer resource */
89 };
90
91 struct pci_dev_info {
92  struct pci_dev_id id;
93  uint8_t rev;
94  uint8_t irq; /* 0 = NO IRQ */
95  pci_dev_t pcidev;
96  struct pcibus_res resources[PCIDEV_RES_CNT];
97  struct pci_dev *pci_device;
98 };
99
100 struct pci_drv_info {
101  struct drvmgr_drv general; /* General bus info */
102  /* PCI specific bus information */
103  struct pci_dev_id_match *ids; /* Supported hardware */
104 };
105
106 /* Access routines */
107 struct pcibus_regmem_ops {
108  drvmgr_r8 r8;
109  drvmgr_r16 r16;
110  drvmgr_r32 r32;
111  drvmgr_r64 r64;
112  drvmgr_w8 w8;
113  drvmgr_w16 w16;
114  drvmgr_w32 w32;
115  drvmgr_w64 w64;
116 };
117
118 /* Let driver configure PCI bus driver */
119 struct pcibus_config {
120  struct drvmgr_map_entry *maps_up;
121  struct drvmgr_map_entry *maps_down;
122 };
123
124 /* PCI Configuration Space Access - Not implemented (use PCI Lib directly) */
125 #define PCI_FUNC_CFG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_CFG)
126 #define PCI_FUNC_CFG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_CFG)
127 #define PCI_FUNC_CFG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_CFG)
128 #define PCI_FUNC_CFG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_CFG)
129 #define PCI_FUNC_CFG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_CFG)
130 #define PCI_FUNC_CFG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_CFG)
131
132 /* PCI I/O Register Access - Not implemented (use PCI Lib directly) */
133 #define PCI_FUNC_IO_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_IO)
134 #define PCI_FUNC_IO_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_IO)
135 #define PCI_FUNC_IO_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_IO)
136 #define PCI_FUNC_IO_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_IO)
137 #define PCI_FUNC_IO_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_IO)
138 #define PCI_FUNC_IO_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_IO)
139
140 /* PCI Register Access over Memory Space (Little Endian) */
141 #define PCI_FUNC_MREG_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_MEMREG)
142 #define PCI_FUNC_MREG_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_MEMREG|RW_LITTLE)
143 #define PCI_FUNC_MREG_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_MEMREG|RW_LITTLE)
144 #define PCI_FUNC_MREG_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_MEMREG)
145 #define PCI_FUNC_MREG_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_MEMREG|RW_LITTLE)
146 #define PCI_FUNC_MREG_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_MEMREG|RW_LITTLE)
147
148 /* Weak default PCI driver resources, override this from project configuration
149  * to set PCI Bus resources used to configure PCI device drivers.
150  */
151 extern struct drvmgr_bus_res pcibus_drv_resources;
152
153 /* Attach a PCI bus on top of a PCI Host device */
154 extern int pcibus_register(struct drvmgr_dev *dev, struct pcibus_config *cfg);
155
156 #ifdef __cplusplus
157 }
158 #endif
159
160 #endif
Definition: pci_bus.h:120
Definition: pci_bus.h:60
Definition: pci_bus.h:86
Bus resource list node.
Definition: drvmgr.h:210
Definition: pci_bus.h:92
MAP entry.
Definition: drvmgr.h:221
Definition: pci_bus.h:52
Device information.
Definition: drvmgr.h:271
Definition: cfg.h:145
Definition: pci_bus.h:101
Definition: cfg.h:211
Device driver description.
Definition: drvmgr.h:301
Definition: pci_bus.h:108
