ip_mroute.h
1 /*
2  * Copyright (c) 1989 Stephen Deering.
3  * Copyright (c) 1992, 1993
4  * The Regents of the University of California. All rights reserved.
5  *
6  * This code is derived from software contributed to Berkeley by
7  * Stephen Deering of Stanford University.
8  *
9  * Redistribution and use in source and binary forms, with or without
10  * modification, are permitted provided that the following conditions
11  * are met:
12  * 1. Redistributions of source code must retain the above copyright
13  * notice, this list of conditions and the following disclaimer.
14  * 2. Redistributions in binary form must reproduce the above copyright
15  * notice, this list of conditions and the following disclaimer in the
16  * documentation and/or other materials provided with the distribution.
17  * 4. Neither the name of the University nor the names of its contributors
18  * may be used to endorse or promote products derived from this software
19  * without specific prior written permission.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31  * SUCH DAMAGE.
32  *
33  * @(#)ip_mroute.h 8.1 (Berkeley) 6/10/93
34  * $FreeBSD: src/sys/netinet/ip_mroute.h,v 1.31 2007/02/08 23:05:08 bms Exp $
35  */
36
37
38 #ifndef _NETINET_IP_MROUTE_H_
39 #define _NETINET_IP_MROUTE_H_
40
41 #include <netinet/in.h> /* struct in_addr */
42 #include <net/route.h> /* struct route */
43
44 /*
45  * Definitions for IP multicast forwarding.
46  *
47  * Written by David Waitzman, BBN Labs, August 1988.
48  * Modified by Steve Deering, Stanford, February 1989.
49  * Modified by Ajit Thyagarajan, PARC, August 1993.
50  * Modified by Ajit Thyagarajan, PARC, August 1994.
51  * Modified by Ahmed Helmy, SGI, June 1996.
52  * Modified by Pavlin Radoslavov, ICSI, October 2002.
53  *
54  * MROUTING Revision: 3.3.1.3
55  * and PIM-SMv2 and PIM-DM support, advanced API support,
56  * bandwidth metering and signaling.
57  */
58
59
60 /*
61  * Multicast Routing set/getsockopt commands.
62  */
63 #define MRT_INIT 100 /* initialize forwarder */
64 #define MRT_DONE 101 /* shut down forwarder */
65 #define MRT_ADD_VIF 102 /* create virtual interface */
66 #define MRT_DEL_VIF 103 /* delete virtual interface */
67 #define MRT_ADD_MFC 104 /* insert forwarding cache entry */
68 #define MRT_DEL_MFC 105 /* delete forwarding cache entry */
69 #define MRT_VERSION 106 /* get kernel version number */
70 #define MRT_ASSERT 107 /* enable assert processing */
71 #define MRT_PIM MRT_ASSERT /* enable PIM processing */
72 #define MRT_API_SUPPORT 109 /* supported MRT API */
73 #define MRT_API_CONFIG 110 /* config MRT API */
74 #define MRT_ADD_BW_UPCALL 111 /* create bandwidth monitor */
75 #define MRT_DEL_BW_UPCALL 112 /* delete bandwidth monitor */
76
77
78 #define GET_TIME(t) microtime(&t)
79
80 /*
81  * Types and macros for handling bitmaps with one bit per virtual interface.
82  */
83 #define MAXVIFS 32
84 typedef u_long vifbitmap_t;
85 typedef u_short vifi_t; /* type of a vif index */
86 #define ALL_VIFS (vifi_t)-1
87
88 #define VIFM_SET(n, m) ((m) |= (1 << (n)))
89 #define VIFM_CLR(n, m) ((m) &= ~(1 << (n)))
90 #define VIFM_ISSET(n, m) ((m) & (1 << (n)))
91 #define VIFM_CLRALL(m) ((m) = 0x00000000)
92 #define VIFM_COPY(mfrom, mto) ((mto) = (mfrom))
93 #define VIFM_SAME(m1, m2) ((m1) == (m2))
94
95
96 /*
97  * Argument structure for MRT_ADD_VIF.
98  * (MRT_DEL_VIF takes a single vifi_t argument.)
99  */
100 struct vifctl {
101  vifi_t vifc_vifi; /* the index of the vif to be added */
102  u_char vifc_flags; /* VIFF_ flags defined below */
103  u_char vifc_threshold; /* min ttl required to forward on vif */
104  u_int vifc_rate_limit; /* max rate */
105  struct in_addr vifc_lcl_addr; /* local interface address */
106  struct in_addr vifc_rmt_addr; /* remote address (tunnels only) */
107 };
108
109 #define VIFF_TUNNEL 0x1 /* vif represents a tunnel end-point */
110 #define VIFF_SRCRT 0x2 /* tunnel uses IP source routing */
111
112 /*
113  * Argument structure for MRT_ADD_MFC and MRT_DEL_MFC
114  * (mfcc_tos to be added at a future point)
115  */
116 struct mfcctl {
117  struct in_addr mfcc_origin; /* ip origin of mcasts */
118  struct in_addr mfcc_mcastgrp; /* multicast group associated*/
119  vifi_t mfcc_parent; /* incoming vif */
120  u_char mfcc_ttls[MAXVIFS]; /* forwarding ttls on vifs */
121 };
122
123 /*
124  * The kernel's multicast routing statistics.
125  */
126 struct mrtstat {
127  u_long mrts_mfc_lookups; /* # forw. cache hash table hits */
128  u_long mrts_mfc_misses; /* # forw. cache hash table misses */
129  u_long mrts_upcalls; /* # calls to mrouted */
130  u_long mrts_no_route; /* no route for packet's origin */
131  u_long mrts_bad_tunnel; /* malformed tunnel options */
132  u_long mrts_cant_tunnel; /* no room for tunnel options */
133  u_long mrts_wrong_if; /* arrived on wrong interface */
134  u_long mrts_upq_ovflw; /* upcall Q overflow */
135  u_long mrts_cache_cleanups; /* # entries with no upcalls */
136  u_long mrts_drop_sel; /* pkts dropped selectively */
137  u_long mrts_q_overflow; /* pkts dropped - Q overflow */
138  u_long mrts_pkt2large; /* pkts dropped - size > BKT SIZE */
139  u_long mrts_upq_sockfull; /* upcalls dropped - socket full */
140 };
141
142 /*
143  * Argument structure used by mrouted to get src-grp pkt counts
144  */
145 struct sioc_sg_req {
146  struct in_addr src;
147  struct in_addr grp;
148  u_long pktcnt;
149  u_long bytecnt;
150  u_long wrong_if;
151 };
152
153 /*
154  * Argument structure used by mrouted to get vif pkt counts
155  */
156 struct sioc_vif_req {
157  vifi_t vifi; /* vif number */
158  u_long icount; /* Input packet count on vif */
159  u_long ocount; /* Output packet count on vif */
160  u_long ibytes; /* Input byte count on vif */
161  u_long obytes; /* Output byte count on vif */
162 };
163
164
165 /*
166  * The kernel's virtual-interface structure.
167  */
168 struct vif {
169  u_char v_flags; /* VIFF_ flags defined above */
170  u_char v_threshold; /* min ttl required to forward on vif*/
171  u_int v_rate_limit; /* max rate */
172  struct tbf *v_tbf; /* token bucket structure at intf. */
173  struct in_addr v_lcl_addr; /* local interface address */
174  struct in_addr v_rmt_addr; /* remote address (tunnels only) */
175  struct ifnet *v_ifp; /* pointer to interface */
176  u_long v_pkt_in; /* # pkts in on interface */
177  u_long v_pkt_out; /* # pkts out on interface */
178  u_long v_bytes_in; /* # bytes in on interface */
179  u_long v_bytes_out; /* # bytes out on interface */
180  struct route v_route; /* cached route if this is a tunnel */
181  u_int v_rsvp_on; /* RSVP listening on this vif */
182  struct socket *v_rsvpd; /* RSVP daemon socket */
183 };
184
185 /*
186  * The kernel's multicast forwarding cache entry structure
187  * (A field for the type of service (mfc_tos) is to be added
188  * at a future point)
189  */
190 struct mfc {
191  struct in_addr mfc_origin; /* IP origin of mcasts */
192  struct in_addr mfc_mcastgrp; /* multicast group associated*/
193  vifi_t mfc_parent; /* incoming vif */
194  u_char mfc_ttls[MAXVIFS]; /* forwarding ttls on vifs */
195  u_long mfc_pkt_cnt; /* pkt count for src-grp */
196  u_long mfc_byte_cnt; /* byte count for src-grp */
197  u_long mfc_wrong_if; /* wrong if for src-grp */
198  int mfc_expire; /* time to clean entry up */
199  struct timeval mfc_last_assert; /* last time I sent an assert*/
200 };
201
202 /*
203  * Struct used to communicate from kernel to multicast router
204  * note the convenient similarity to an IP packet
205  */
206 struct igmpmsg {
207  u_long unused1;
208  u_long unused2;
209  u_char im_msgtype; /* what type of message */
210 #define IGMPMSG_NOCACHE 1
211 #define IGMPMSG_WRONGVIF 2
212  u_char im_mbz; /* must be zero */
213  u_char im_vif; /* vif rec'd on */
214  u_char unused3;
215  struct in_addr im_src, im_dst;
216 };
217
218 /*
219  * Argument structure used for pkt info. while upcall is made
220  */
221 struct rtdetq {
222  struct mbuf *m; /* A copy of the packet */
223  struct ifnet *ifp; /* Interface pkt came in on */
224  vifi_t xmt_vif; /* Saved copy of imo_multicast_vif */
225 #ifdef UPCALL_TIMING
226  struct timeval t; /* Timestamp */
227 #endif /* UPCALL_TIMING */
228 };
229
230 #define MFCTBLSIZ 256
231 #if (MFCTBLSIZ & (MFCTBLSIZ - 1)) == 0 /* from sys:route.h */
232 #define MFCHASHMOD(h) ((h) & (MFCTBLSIZ - 1))
233 #else
234 #define MFCHASHMOD(h) ((h) % MFCTBLSIZ)
235 #endif
236
237 #define MAX_UPQ 4 /* max. no of pkts in upcall Q */
238
239 /*
240  * Token Bucket filter code
241  */
242 #define MAX_BKT_SIZE 10000 /* 10K bytes size */
243 #define MAXQSIZE 10 /* max # of pkts in queue */
244
245 /*
246  * the token bucket filter at each vif
247  */
248 struct tbf
249 {
250  struct timeval tbf_last_pkt_t; /* arr. time of last pkt */
251  u_long tbf_n_tok; /* no of tokens in bucket */
252  u_long tbf_q_len; /* length of queue at this vif */
253  u_long tbf_max_q_len; /* max. queue length */
254  struct mbuf *tbf_q; /* Packet queue */
255  struct mbuf *tbf_t; /* tail-insertion pointer */
256 };
257
258 #ifdef _KERNEL
259
260 extern int (*ip_mrouter_set)(int, struct socket *, struct mbuf *);
261 extern int (*ip_mrouter_get)(int, struct socket *, struct mbuf **);
262 extern int (*ip_mrouter_done)(void);
263 #ifdef MROUTING
264 extern int (*mrt_ioctl)(int, caddr_t);
265 #else
266 extern int (*mrt_ioctl)(int, caddr_t, struct proc *);
267 #endif
268
269 #endif /* _KERNEL */
270
271 #endif /* _NETINET_IP_MROUTE_H_ */
Definition: ip_mroute.h:127
Definition: ip_mroute.h:101
Definition: ip_mroute.h:207
Definition: ip_mroute.h:117
Definition: socketvar.h:49
Definition: ip_mroute.h:191
Definition: proc.h:5
Definition: route.h:51
Definition: ip_mroute.h:146
Definition: ip_mroute.h:222
Definition: ip_mroute.h:169
Definition: inet.h:93
Definition: if_var.h:99
Definition: mbuf.h:103
Definition: ip_mroute.h:157
Definition: ip_mroute.h:249
