#define | MRT_INIT 100 /* initialize forwarder */ |
#define | MRT_DONE 101 /* shut down forwarder */ |
#define | MRT_ADD_VIF 102 /* create virtual interface */ |
#define | MRT_DEL_VIF 103 /* delete virtual interface */ |
#define | MRT_ADD_MFC 104 /* insert forwarding cache entry */ |
#define | MRT_DEL_MFC 105 /* delete forwarding cache entry */ |
#define | MRT_VERSION 106 /* get kernel version number */ |
#define | MRT_ASSERT 107 /* enable assert processing */ |
#define | MRT_PIM MRT_ASSERT /* enable PIM processing */ |
#define | MRT_API_SUPPORT 109 /* supported MRT API */ |
#define | MRT_API_CONFIG 110 /* config MRT API */ |
#define | MRT_ADD_BW_UPCALL 111 /* create bandwidth monitor */ |
#define | MRT_DEL_BW_UPCALL 112 /* delete bandwidth monitor */ |
#define | GET_TIME(t) microtime(&t) |
#define | MAXVIFS 32 |
#define | ALL_VIFS (vifi_t)-1 |
#define | VIFM_SET(n, m) ((m) |= (1 << (n))) |
#define | VIFM_CLR(n, m) ((m) &= ~(1 << (n))) |
#define | VIFM_ISSET(n, m) ((m) & (1 << (n))) |
#define | VIFM_CLRALL(m) ((m) = 0x00000000) |
#define | VIFM_COPY(mfrom, mto) ((mto) = (mfrom)) |
#define | VIFM_SAME(m1, m2) ((m1) == (m2)) |
#define | VIFF_TUNNEL 0x1 /* vif represents a tunnel end-point */ |
#define | VIFF_SRCRT 0x2 /* tunnel uses IP source routing */ |
#define | IGMPMSG_NOCACHE 1 |
#define | IGMPMSG_WRONGVIF 2 |
#define | MFCTBLSIZ 256 |
#define | MFCHASHMOD(h) ((h) & (MFCTBLSIZ - 1)) |
#define | MAX_UPQ 4 /* max. no of pkts in upcall Q */ |
#define | MAX_BKT_SIZE 10000 /* 10K bytes size */ |
#define | MAXQSIZE 10 /* max # of pkts in queue */ |
