if_var.h
1 /*
2  * Copyright (c) 1982, 1986, 1989, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 4. Neither the name of the University nor the names of its contributors
14  * may be used to endorse or promote products derived from this software
15  * without specific prior written permission.
16  *
17  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27  * SUCH DAMAGE.
28  *
29  * From: @(#)if.h 8.1 (Berkeley) 6/10/93
30  * $FreeBSD: src/sys/net/if_var.h,v 1.107 2006/06/19 22:20:44 mlaier Exp $
31  */
32
33
34 #ifndef _NET_IF_VAR_H_
35 #define _NET_IF_VAR_H_
36
37 #include <net/if.h> /* struct if_data */
38 #include <sys/ioccom.h> /* ioctl_command_t */
39
40 /*
41  * Structures defining a network interface, providing a packet
42  * transport mechanism (ala level 0 of the PUP protocols).
43  *
44  * Each interface accepts output datagrams of a specified maximum
45  * length, and provides higher level routines with input datagrams
46  * received from its medium.
47  *
48  * Output occurs when the routine if_output is called, with three parameters:
49  * (*ifp->if_output)(ifp, m, dst, rt)
50  * Here m is the mbuf chain to be sent and dst is the destination address.
51  * The output routine encapsulates the supplied datagram if necessary,
52  * and then transmits it on its medium.
53  *
54  * On input, each interface unwraps the data received by it, and either
55  * places it on the input queue of an internetwork datagram routine
56  * and posts the associated software interrupt, or passes the datagram to a raw
57  * packet input routine.
58  *
59  * Routines exist for locating interfaces by their addresses
60  * or for locating an interface on a certain network, as well as more general
61  * routing and gateway routines maintaining information used to locate
62  * interfaces. These routines live in the files if.c and route.c
63  */
64
65 /*
66  * Forward structure declarations for function prototypes [sic].
67  */
68 struct mbuf;
69 #ifndef __rtems__
70 struct thread;
71 #endif
72 struct rtentry;
73 struct rt_addrinfo;
74 struct socket;
75 struct ether_header;
76 #ifndef __rtems__
77 struct carp_if;
78 #endif
79
80 #include <sys/queue.h> /* get TAILQ macros */
81
82 /*
83  * Structure defining a queue for a network interface.
84  */
85 struct ifqueue {
86  struct mbuf *ifq_head;
87  struct mbuf *ifq_tail;
88  int ifq_len;
89  int ifq_maxlen;
90  int ifq_drops;
91 };
92
93 /*
94  * Structure defining a network interface.
95  *
96  * (Would like to call this struct ``if'', but C isn't PL/1.)
97  */
98 struct ifnet {
99  void *if_softc; /* pointer to driver state */
100  char *if_name; /* name, e.g. ``en'' or ``lo'' */
101  struct ifnet *if_next; /* all struct ifnets are chained */
102  struct ifaddr *if_addrlist; /* linked list of addresses per if */
103  int if_pcount; /* number of promiscuous listeners */
104  struct bpf_if *if_bpf; /* packet filter structure */
105  u_short if_index; /* numeric abbreviation for this if */
106  short if_unit; /* sub-unit for lower level driver */
107  short if_timer; /* time 'til if_watchdog called */
108  int if_flags; /* up/down, broadcast, etc. */
109  void *if_linkmib; /* link-type-specific MIB data */
110  size_t if_linkmiblen; /* length of above data */
111  struct if_data if_data;
112 /* procedure handles */
113  int (*if_output) /* output routine (enqueue) */
114  (struct ifnet *, struct mbuf *, struct sockaddr *,
115  struct rtentry *);
116  void (*if_start) /* initiate output routine */
117  (struct ifnet *);
118  int (*if_ioctl) /* ioctl routine */
119  (struct ifnet *, ioctl_command_t, caddr_t);
120  void (*if_watchdog) /* timer routine */
121  (struct ifnet *);
122  int (*if_poll_recv) /* polled receive routine */
123  (struct ifnet *, int *);
124  int (*if_poll_xmit) /* polled transmit routine */
125  (struct ifnet *, int *);
126  void (*if_poll_intren) /* polled interrupt reenable routine */
127  (struct ifnet *);
128  void (*if_poll_slowinput) /* input routine for slow devices */
129  (struct ifnet *, struct mbuf *);
130  void (*if_init) /* Init routine */
131  (void *);
132  int (*if_tap) /* Packet filter routine */
133  (struct ifnet *, struct ether_header *, struct mbuf *);
134  struct ifqueue if_snd; /* output queue */
135  struct ifqueue *if_poll_slowq; /* input queue for slow devices */
136 };
137
138 typedef void if_init_f_t(void *);
139
140 /*
141  * XXX These aliases are terribly dangerous because they could apply
142  * to anything.
143  */
144 #define if_mtu if_data.ifi_mtu
145 #define if_type if_data.ifi_type
146 #define if_physical if_data.ifi_physical
147 #define if_addrlen if_data.ifi_addrlen
148 #define if_hdrlen if_data.ifi_hdrlen
149 #define if_metric if_data.ifi_metric
150 #define if_baudrate if_data.ifi_baudrate
151 #define if_ipackets if_data.ifi_ipackets
152 #define if_ierrors if_data.ifi_ierrors
153 #define if_opackets if_data.ifi_opackets
154 #define if_oerrors if_data.ifi_oerrors
155 #define if_collisions if_data.ifi_collisions
156 #define if_ibytes if_data.ifi_ibytes
157 #define if_obytes if_data.ifi_obytes
158 #define if_imcasts if_data.ifi_imcasts
159 #define if_omcasts if_data.ifi_omcasts
160 #define if_iqdrops if_data.ifi_iqdrops
161 #define if_noproto if_data.ifi_noproto
162 #define if_lastchange if_data.ifi_lastchange
163 #define if_recvquota if_data.ifi_recvquota
164 #define if_xmitquota if_data.ifi_xmitquota
165 #define if_rawoutput(if, m, sa) if_output(if, m, sa, (struct rtentry *)NULL)
166
167 /*
168  * Output queues (ifp->if_snd) and slow device input queues (*ifp->if_slowq)
169  * are queues of messages stored on ifqueue structures
170  * (defined above). Entries are added to and deleted from these structures
171  * by these macros, which should be called with ipl raised to splimp().
172  */
173 #define IF_QFULL(ifq) ((ifq)->ifq_len >= (ifq)->ifq_maxlen)
174 #define IF_DROP(ifq) ((ifq)->ifq_drops++)
175
176 #define IF_ENQUEUE(ifq, m) do { \
177  (m)->m_nextpkt = NULL; \
178  if ((ifq)->ifq_tail == NULL) \
179  (ifq)->ifq_head = m; \
180  else \
181  (ifq)->ifq_tail->m_nextpkt = m; \
182  (ifq)->ifq_tail = m; \
183  (ifq)->ifq_len++; \
184 } while (0)
185
186 #define IF_PREPEND(ifq, m) do { \
187  (m)->m_nextpkt = (ifq)->ifq_head; \
188  if ((ifq)->ifq_tail == NULL) \
189  (ifq)->ifq_tail = (m); \
190  (ifq)->ifq_head = (m); \
191  (ifq)->ifq_len++; \
192 } while (0)
193
194 #define IF_DEQUEUE(ifq, m) do { \
195  (m) = (ifq)->ifq_head; \
196  if (m) { \
197  if (((ifq)->ifq_head = (m)->m_nextpkt) == NULL) \
198  (ifq)->ifq_tail = NULL; \
199  (m)->m_nextpkt = NULL; \
200  (ifq)->ifq_len--; \
201  } \
202 } while (0)
203
204 /*
205  * The ifaddr structure contains information about one address
206  * of an interface. They are maintained by the different address families,
207  * are allocated and attached when an address is set, and are linked
208  * together so all addresses for an interface can be located.
209  */
210 struct ifaddr {
211  struct sockaddr *ifa_addr; /* address of interface */
212  struct sockaddr *ifa_dstaddr; /* other end of p-to-p link */
213 #define ifa_broadaddr ifa_dstaddr /* broadcast address interface */
214  struct sockaddr *ifa_netmask; /* used to determine subnet */
215  struct ifnet *ifa_ifp; /* back-pointer to interface */
216  struct ifaddr *ifa_next; /* next address for interface */
217  void (*ifa_rtrequest) /* check or clean routes (+ or -)'d */
218  (int, struct rtentry *, struct sockaddr *);
219  u_short ifa_flags; /* mostly rt_flags for cloning */
220  u_int ifa_refcnt; /* references to this structure */
221  int ifa_metric; /* cost of going out this interface */
222  int (*ifa_claim_addr) /* check if an addr goes to this if */
223  (struct ifaddr *, struct sockaddr *);
224
225 };
226 #define IFA_ROUTE RTF_UP /* route installed */
227
228 #ifdef _KERNEL
229 #define IFAFREE(ifa) \
230  if ((ifa)->ifa_refcnt <= 0) \
231  ifafree(ifa); \
232  else \
233  (ifa)->ifa_refcnt--;
234
235 extern struct ifnet *ifnet;
236 extern int ifqmaxlen;
237 extern struct ifnet loif[];
238 extern int if_index;
239 extern struct ifaddr **ifnet_addrs;
240
241 void if_attach(struct ifnet *);
242 void if_down(struct ifnet *);
243 void if_up(struct ifnet *);
244 /*void ifinit(void);*/ /* declared in systm.h for main() */
245 int ifioctl(struct socket *, u_long, caddr_t, struct proc *);
246 int ifpromisc(struct ifnet *, int);
247
248 struct ifaddr *ifa_ifwithaddr(struct sockaddr *);
249 struct ifaddr *ifa_ifwithdstaddr(struct sockaddr *);
250 struct ifaddr *ifa_ifwithnet(struct sockaddr *);
251 struct ifaddr *ifa_ifwithroute(int, struct sockaddr *, struct sockaddr *);
252 struct ifaddr *ifaof_ifpforaddr(struct sockaddr *, struct ifnet *);
253
254 #endif /* _KERNEL */
255
256 #endif /* !_NET_IF_VAR_H_ */
Definition: ethernet.h:62
Definition: socketvar.h:49
Definition: proc.h:5
Definition: route.h:251
Definition: if_var.h:86
Definition: socket.h:180
Definition: if_var.h:211
Definition: mbuf.h:103
Definition: route.h:104
