hexdump.h
1 /*
2  * Copyright (c) 1989, 1993
3  * The Regents of the University of California. All rights reserved.
4  *
5  * Redistribution and use in source and binary forms, with or without
6  * modification, are permitted provided that the following conditions
7  * are met:
8  * 1. Redistributions of source code must retain the above copyright
9  * notice, this list of conditions and the following disclaimer.
10  * 2. Redistributions in binary form must reproduce the above copyright
11  * notice, this list of conditions and the following disclaimer in the
12  * documentation and/or other materials provided with the distribution.
13  * 3. All advertising materials mentioning features or use of this software
14  * must display the following acknowledgement:
15  * This product includes software developed by the University of
16  * California, Berkeley and its contributors.
17  * 4. Neither the name of the University nor the names of its contributors
18  * may be used to endorse or promote products derived from this software
19  * without specific prior written permission.
20  *
21  * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
22  * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24  * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
25  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
26  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
27  * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
28  * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
29  * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
30  * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
31  * SUCH DAMAGE.
32  *
33  * @(#)hexdump.h 8.1 (Berkeley) 6/6/93
34  * $FreeBSD: src/usr.bin/hexdump/hexdump.h,v 1.9 2004/07/11 01:11:12 tjr Exp $
35  */
36
37 #include <wchar.h>
38
39 typedef struct _pr {
40  struct _pr *nextpr; /* next print unit */
41 #define F_ADDRESS 0x001 /* print offset */
42 #define F_BPAD 0x002 /* blank pad */
43 #define F_C 0x004 /* %_c */
44 #define F_CHAR 0x008 /* %c */
45 #define F_DBL 0x010 /* %[EefGf] */
46 #define F_INT 0x020 /* %[di] */
47 #define F_P 0x040 /* %_p */
48 #define F_STR 0x080 /* %s */
49 #define F_U 0x100 /* %_u */
50 #define F_UINT 0x200 /* %[ouXx] */
51 #define F_TEXT 0x400 /* no conversions */
52  u_int flags; /* flag values */
53  int bcnt; /* byte count */
54  char *cchar; /* conversion character */
55  char *fmt; /* printf format */
56  char *nospace; /* no whitespace version */
57  int mbleft; /* bytes left of multibyte char. */
58  mbstate_t mbstate; /* conversion state */
59 } PR;
60
61 typedef struct _fu {
62  struct _fu *nextfu; /* next format unit */
63  struct _pr *nextpr; /* next print unit */
64 #define F_IGNORE 0x01 /* %_A */
65 #define F_SETREP 0x02 /* rep count set, not default */
66  u_int flags; /* flag values */
67  int reps; /* repetition count */
68  int bcnt; /* byte count */
69  char *fmt; /* format string */
70 } FU;
71
72 typedef struct _fs { /* format strings */
73  struct _fs *nextfs; /* linked list of format strings */
74  struct _fu *nextfu; /* linked list of format units */
75  int bcnt;
76 } FS;
77
78 #if 0
79 extern FS *fshead; /* head of format strings list */
80 extern FU *endfu; /* format at end-of-data */
81 extern int blocksize; /* data block size */
82 extern int exitval; /* final exit value */
83 extern int odmode; /* are we acting as od(1)? */
84 extern int length; /* amount of data to read */
85 extern off_t skip; /* amount of data to skip at start */
86 enum _vflag { ALL, DUP, FIRST, WAIT }; /* -v values */
87 extern enum _vflag vflag;
88 #endif
89
90 #include <setjmp.h>
91 #include <stdio.h>
92
93 enum _vflag { ALL, DUP, FIRST, WAIT }; /* -v values */
94 typedef struct rtems_shell_hexdump_globals_t {
95  FS *fshead; /* head of format strings list */
96  FU *endfu; /* format at end-of-data */
97  int blocksize; /* data block size */
98  int exitval; /* final exit value */
99  int odmode; /* are we acting as od(1)? */
100  int length; /* amount of data to read */
101  off_t skip; /* amount of data to skip at start */
102  enum _vflag vflag;
103
104  off_t address;
105  off_t eaddress;
106  int ateof;
107  u_char *curp;
108  u_char *savp;
109  int done;
110
111  FILE* hdstdin;
112
113  int exit_code;
114  jmp_buf exit_jmp;
116
117 #define fshead globals->fshead
118 #define endfu globals->endfu
119 #define blocksize globals->blocksize
120 #define exitval globals->exitval
121 #define odmode globals->odmode
122 #define length globals->length
123 #define skip globals->skip
124 #define vflag globals->vflag
125
126 #define address globals->address
127 #define eaddress globals->eaddress
128 #define ateof globals->ateof
129 #define curp globals->curp
130 #define savp globals->savp
131 #define done globals->done
132
133 #define hdstdin globals->hdstdin
134
135 #define exit_jump &(globals->exit_jmp)
136
137 #define add rtems_shell_hexdump_add
138 #define addfile rtems_shell_hexdump_addfile
139 #define badcnt rtems_shell_hexdump_badcnt
140 #define badconv rtems_shell_hexdump_badconv
141 #define badfmt rtems_shell_hexdump_badfmt
142 #define badsfmt rtems_shell_hexdump_badsfmt
143 #define bpad rtems_shell_hexdump_bpad
144 #define conv_c rtems_shell_hexdump_conv_c
145 #define conv_u rtems_shell_hexdump_conv_u
146 #define display rtems_shell_hexdump_display
147 #define doskip rtems_shell_hexdump_doskip
148 #define escape rtems_shell_hexdump_escape
149 #define get rtems_shell_hexdump_get
150 #define newsyntax rtems_shell_hexdump_newsyntax
151 #define next rtems_shell_hexdump_next
152 #define nomem rtems_shell_hexdump_nomem
153 #define oldsyntax rtems_shell_hexdump_oldsyntax
154 #define peek rtems_shell_hexdump_peek
155 #define rewrite rtems_shell_hexdump_rewrite
156 #define size rtems_shell_hexdump_size
157 #define usage rtems_shell_hexdump_usage
158
159 void add(rtems_shell_hexdump_globals*, const char *);
160 void addfile(rtems_shell_hexdump_globals*, char *);
161 void badcnt(rtems_shell_hexdump_globals*, char *);
162 void badconv(rtems_shell_hexdump_globals*, char *);
163 void badfmt(rtems_shell_hexdump_globals*, const char *);
164 void badsfmt(rtems_shell_hexdump_globals*);
165 void bpad(PR *);
166 void conv_c(rtems_shell_hexdump_globals*, PR *, u_char *, size_t);
167 void conv_u(rtems_shell_hexdump_globals*, PR *, u_char *);
168 void display(rtems_shell_hexdump_globals*);
169 void doskip(rtems_shell_hexdump_globals*, const char *, int);
170 void escape(char *);
171 u_char *get(rtems_shell_hexdump_globals*);
172 void newsyntax(rtems_shell_hexdump_globals*, int, char ***);
173 int next(rtems_shell_hexdump_globals*, char **);
174 void nomem(void);
175 void oldsyntax(rtems_shell_hexdump_globals*, int, char ***);
176 size_t peek(rtems_shell_hexdump_globals*, u_char *, size_t);
177 void rewrite(rtems_shell_hexdump_globals*, FS *);
178 int size(rtems_shell_hexdump_globals*, FS *);
179 void usage(rtems_shell_hexdump_globals*);
180
181 #define exit(ec) rtems_shell_hexdump_exit(globals, ec)
182
183 void rtems_shell_hexdump_exit(rtems_shell_hexdump_globals* globals, int code);
Definition: hexdump.h:62
Definition: hexdump.h:40
Definition: inftrees.h:25
Definition: hexdump.h:73
Definition: hexdump.h:95
