#define | F_ADDRESS 0x001 /* print offset */ |
#define | F_BPAD 0x002 /* blank pad */ |
#define | F_C 0x004 /* %_c */ |
#define | F_CHAR 0x008 /* %c */ |
#define | F_DBL 0x010 /* %[EefGf] */ |
#define | F_INT 0x020 /* %[di] */ |
#define | F_P 0x040 /* %_p */ |
#define | F_STR 0x080 /* %s */ |
#define | F_U 0x100 /* %_u */ |
#define | F_UINT 0x200 /* %[ouXx] */ |
#define | F_TEXT 0x400 /* no conversions */ |
#define | F_IGNORE 0x01 /* %_A */ |
#define | F_SETREP 0x02 /* rep count set, not default */ |
#define | fshead globals->fshead |
#define | endfu globals->endfu |
#define | blocksize globals->blocksize |
#define | exitval globals->exitval |
#define | odmode globals->odmode |
#define | length globals->length |
#define | skip globals->skip |
#define | vflag globals->vflag |
#define | address globals->address |
#define | eaddress globals->eaddress |
#define | ateof globals->ateof |
#define | curp globals->curp |
#define | savp globals->savp |
#define | done globals->done |
#define | hdstdin globals->hdstdin |
#define | exit_jump &(globals->exit_jmp) |
#define | add rtems_shell_hexdump_add |
#define | addfile rtems_shell_hexdump_addfile |
#define | badcnt rtems_shell_hexdump_badcnt |
#define | badconv rtems_shell_hexdump_badconv |
#define | badfmt rtems_shell_hexdump_badfmt |
#define | badsfmt rtems_shell_hexdump_badsfmt |
#define | bpad rtems_shell_hexdump_bpad |
#define | conv_c rtems_shell_hexdump_conv_c |
#define | conv_u rtems_shell_hexdump_conv_u |
#define | display rtems_shell_hexdump_display |
#define | doskip rtems_shell_hexdump_doskip |
#define | escape rtems_shell_hexdump_escape |
#define | get rtems_shell_hexdump_get |
#define | newsyntax rtems_shell_hexdump_newsyntax |
#define | next rtems_shell_hexdump_next |
#define | nomem rtems_shell_hexdump_nomem |
#define | oldsyntax rtems_shell_hexdump_oldsyntax |
#define | peek rtems_shell_hexdump_peek |
#define | rewrite rtems_shell_hexdump_rewrite |
#define | size rtems_shell_hexdump_size |
#define | usage rtems_shell_hexdump_usage |
#define | exit(ec) rtems_shell_hexdump_exit(globals, ec) |
void | add (rtems_shell_hexdump_globals *, const char *) |
void | addfile (rtems_shell_hexdump_globals *, char *) |
void | badcnt (rtems_shell_hexdump_globals *, char *) |
void | badconv (rtems_shell_hexdump_globals *, char *) |
void | badfmt (rtems_shell_hexdump_globals *, const char *) |
void | badsfmt (rtems_shell_hexdump_globals *) |
void | bpad (PR *) |
void | conv_c (rtems_shell_hexdump_globals *, PR *, u_char *, size_t) |
void | conv_u (rtems_shell_hexdump_globals *, PR *, u_char *) |
void | display (rtems_shell_hexdump_globals *) |
void | doskip (rtems_shell_hexdump_globals *, const char *, int) |
void | escape (char *) |
u_char * | get (rtems_shell_hexdump_globals *) |
void | newsyntax (rtems_shell_hexdump_globals *, int, char ***) |
int | next (rtems_shell_hexdump_globals *, char **) |
void | nomem (void) |
void | oldsyntax (rtems_shell_hexdump_globals *, int, char ***) |
size_t | peek (rtems_shell_hexdump_globals *, u_char *, size_t) |
void | rewrite (rtems_shell_hexdump_globals *, FS *) |
int | size (rtems_shell_hexdump_globals *, FS *) |
void | usage (rtems_shell_hexdump_globals *) |
void | rtems_shell_hexdump_exit (rtems_shell_hexdump_globals *globals, int code) |
