In addition to the Classic API interrupt handler with a handle are supported. More...
Files | |
file | irq-extension.h |
Header file for the Interrupt Manager Extension. | |
#define | RTEMS_INTERRUPT_UNIQUE ((rtems_option) 0x00000001) |
Makes the interrupt handler unique. More... | |
#define | RTEMS_INTERRUPT_SHARED ((rtems_option) 0x00000000) |
Allows that this interrupt handler may share a common interrupt vector with other handler. | |
#define | RTEMS_INTERRUPT_REPLACE ((rtems_option) 0x00000002) |
Forces that this interrupt handler replaces the first handler with the same argument. | |
#define | RTEMS_INTERRUPT_IS_UNIQUE(options) ((options) & RTEMS_INTERRUPT_UNIQUE) |
Returns true if the interrupt handler unique option is set. | |
#define | RTEMS_INTERRUPT_IS_SHARED(options) (!RTEMS_INTERRUPT_IS_UNIQUE( options)) |
Returns true if the interrupt handler shared option is set. | |
#define | RTEMS_INTERRUPT_IS_REPLACE(options) ((options) & RTEMS_INTERRUPT_REPLACE) |
Returns true if the interrupt handler replace option is set. | |
Typedefs | |
typedef void(* | rtems_interrupt_handler) (void *) |
Interrupt handler routine type. | |
typedef void(* | rtems_interrupt_per_handler_routine) (void *, const char *, rtems_option, rtems_interrupt_handler, void *) |
Interrupt handler iteration routine type. More... | |
rtems_status_code | rtems_interrupt_handler_install (rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg) |
Installs the interrupt handler routine handler for the interrupt vector with number vector. More... | |
rtems_status_code | rtems_interrupt_handler_remove (rtems_vector_number vector, rtems_interrupt_handler handler, void *arg) |
Removes the interrupt handler routine handler with argument arg for the interrupt vector with number vector. More... | |
rtems_status_code | rtems_interrupt_handler_iterate (rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg) |
Iterates over all installed interrupt handler of the interrupt vector with number vector. More... | |
rtems_status_code | rtems_interrupt_server_initialize (rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes, rtems_id *server) |
Initializes an interrupt server task. More... | |
rtems_status_code | rtems_interrupt_server_handler_install (rtems_id server, rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler handler, void *arg) |
Installs the interrupt handler routine handler for the interrupt vector with number vector on the server server. More... | |
rtems_status_code | rtems_interrupt_server_handler_remove (rtems_id server, rtems_vector_number vector, rtems_interrupt_handler handler, void *arg) |
Removes the interrupt handler routine handler with argument arg for the interrupt vector with number vector from the server server. More... | |
You can also install multiple shared handler for one interrupt vector.
#define RTEMS_INTERRUPT_UNIQUE ((rtems_option) 0x00000001) |
Prevents other handler from using the same interrupt vector.
typedef void(* rtems_interrupt_per_handler_routine) (void *, const char *, rtems_option, rtems_interrupt_handler, void *) |
rtems_status_code rtems_interrupt_handler_install | ( | rtems_vector_number | vector, |
const char * | info, | ||
rtems_option | options, | ||
rtems_interrupt_handler | handler, | ||
void * | arg | ||
You can set one of the mutually exclusive options
with the options parameter for the interrupt handler.
The handler routine shall be called with argument arg when dispatched. The order in which the shared interrupt handlers are dispatched for one vector is BSP dependent.
If the option RTEMS_INTERRUPT_UNIQUE is set then it shall be ensured that this handler will be the only one for this vector.
If the option RTEMS_INTERRUPT_REPLACE is set then it shall be ensured that this handler will replace the first handler with the same argument for this vector if it exists, otherwise an error status shall be returned. A second handler with the same argument for this vector shall remain unchanged. The new handler will inherit the unique or shared option from the replaced handler.
You can provide an informative description info. This may be used for system debugging and status tools. The string has to be persistent during the handler life time.
This function may block.
RTEMS_SUCCESSFUL | Shall be returned in case of success. |
RTEMS_CALLED_FROM_ISR | If this function is called from interrupt context this shall be returned. |
RTEMS_INVALID_ADDRESS | If the handler address is NULL this shall be returned. |
RTEMS_INVALID_ID | If the vector number is out of range this shall be returned. |
RTEMS_INVALID_NUMBER | If an option is not applicable this shall be returned. |
RTEMS_RESOURCE_IN_USE | If the vector is already occupied with a unique handler this shall be returned. If a unique handler should be installed and there is already a handler installed this shall be returned. |
RTEMS_TOO_MANY | If a handler with this argument is already installed for the vector this shall be returned. |
RTEMS_UNSATISFIED | If no handler exists to replace with the specified argument and vector this shall be returned. |
RTEMS_IO_ERROR | Reserved for board support package specific error conditions. |
rtems_status_code rtems_interrupt_handler_iterate | ( | rtems_vector_number | vector, |
rtems_interrupt_per_handler_routine | routine, | ||
void * | arg | ||
For each installed handler of the vector the function routine will be called with the supplied argument arg and the handler information, options, routine and argument.
This function is intended for system information and diagnostics.
This function may block. Never install or remove an interrupt handler within the iteration routine. This may result in a deadlock.
rtems_status_code rtems_interrupt_handler_remove | ( | rtems_vector_number | vector, |
void * | arg | ||
RTEMS_UNSATISFIED | If the handler with its argument is not installed for the vector this shall be returned. |
rtems_status_code rtems_interrupt_server_handler_install | ( | rtems_id | server, |
rtems_vector_number | vector, | ||
void * | arg | ||
The handler routine will be executed on the corresponding interrupt server task. A server identifier server of RTEMS_ID_NONE
may be used to install the handler on the default server.
RTEMS_INCORRECT_STATE | If the interrupt handler server is not initialized this shall be returned. |
* | For other errors see rtems_interrupt_handler_install(). |
rtems_status_code rtems_interrupt_server_handler_remove | ( | rtems_id | server, |
void * | arg | ||
may be used to remove the handler from the default server.
* | For other errors see rtems_interrupt_handler_remove(). |
rtems_status_code rtems_interrupt_server_initialize | ( | rtems_task_priority | priority, |
size_t | stack_size, | ||
rtems_mode | modes, | ||
rtems_attribute | attributes, | ||
rtems_id * | server | ||
The task will have the priority priority, the stack size stack_size, the modes modes and the attributes attributes. The identifier of the server task will be returned in server. Interrupt handlers can be installed on the server with rtems_interrupt_server_handler_install() and removed with rtems_interrupt_server_handler_remove() using this identifier. In case of an interrupt the request will be forwarded to the server. The handlers are executed within the server context. If one handler blocks on something this may delay the processing of other handlers.
The server identifier pointer server may be NULL to initialize the default server.
RTEMS_INCORRECT_STATE | If the default server is already initialized this shall be returned. |
