Macros | Typedefs | Functions
Mouse Parser Engine
#define RBUTTON   MV_BUTTON_RIGHT
 This is the mask for the right button. More...
#define MBUTTON   MV_BUTTON_CENTER
 This is the mask for the center button. More...
#define LBUTTON   MV_BUTTON_LEFT
 This is the mask for the left button. More...
typedef int COORD
 This type is the device coordinates.
typedef unsigned int BUTTON
 This type is the mouse button mask.
typedef void(* mouse_parser_enqueue_handler) (unsigned char *, size_t)
 This type defines a pointer to the enqueue method. More...
int mouse_parser_initialize (const char *type)
 Initialize the mouse parser engine. More...
void mouse_parser_enqueue (unsigned char *buffer, size_t size)
 Enqueue input to the mouse parser engine. More...
◆ LBUTTON
Note
Use the same definitions as the user interface.
◆ MBUTTON
Note
◆ RBUTTON
Note
Typedef Documentation
◆ mouse_parser_enqueue_handler
It is available since some device drivers keep pointers to the method to know when to enqueue or not.
◆ mouse_parser_enqueue()
void mouse_parser_enqueue ( unsigned char *  buffer,
size_t  size
This method is used to pass mouse input to the Mouse Parser Engine.
param[in] buffer is the data to enqueue param[in] size is the amount of data to enqueue
◆ mouse_parser_initialize()
int mouse_parser_initialize ( const char *  type)
This method initializes the Mouse Parser Engine for the mouse of type. The type should be one of the following strings: pc ms, logi, ps2.
param[in] type indicates the type of mouse.
Return values
Thismethod returns 0 on success and -1 on error.
