Files | Data Structures | Macros | Enumerations | Functions
Input Devices for MicroWindows
Input Devices for MicroWindows. More...
file  mw_print.c
 MicroWindows Print.
file  mw_uid.c
 MicroWindows UIDThis module implements the input devices interface used by MicroWindows in an embedded system environment.
struct  MW_UID_MESSAGE
#define MW_UID_REGISTER_DEVICE   0x4100
#define MW_UID_UNREGISTER_DEVICE   0x4101
#define MV_BUTTON_RIGHT   0x01
#define MV_BUTTON_CENTER   0x02
#define MV_BUTTON_LEFT   0x04
#define MV_KEY_MODIFIER_SHIFT_DOWN   0x10
#define MV_KEY_MODIFIER_ALT_DOWN   0x20
#define MV_KEY_MODIFIER_CAPS_ON   0x04
#define MV_KEY_MODIFIER_NUN_LOCK_ON   0x02
#define MV_KEY_SCROLL_LOCK_ON   0x01
#define MV_KEY_MODE_ASCII   0x01
#define MV_KEY_MODE_SCANCODE   0x00
#define MV_KDGKBMODE   0x4B44 /* gets current keyboard mode */
#define MV_KDSKBMODE   0x4B45 /* sets current keyboard mode */
enum  MW_INPUT_DEVICE_TYPE {
  MV_UID_INVALID = 0, MV_UID_REL_POS = 1, MV_UID_ABS_POS = 2, MV_UID_KBD = 3,
  MV_UID_TIMER = 4
int uid_open_queue (const char *q_name, int flags, size_t max_msgs)
 This method creates the message queue that holds events from the input devices. More...
int uid_close_queue (void)
 This method closes the message queue and deletes it. More...
int uid_read_message (struct MW_UID_MESSAGE *m, unsigned long timeout)
 This method reads a message from the queue. More...
int uid_send_message (struct MW_UID_MESSAGE *m)
 This methods writes a message to the queue. More...
int uid_register_device (int fd, const char *q_name)
 This method registers the device associated with fd to to insert data to the queue.
int uid_unregister_device (int fd)
int uid_set_kbd_mode (int fd, int mode, int *old_mode)
void uid_print_message (struct MW_UID_MESSAGE *uid)
 This methods prints the specified UID message using printk. More...
void uid_print_message_with_plugin (void *context, rtems_printk_plugin_t handler, struct MW_UID_MESSAGE *uid)
 This methods prints the specified UID message using your fprintf style method of choice. More...
This file defines the interface for input devices used by MicroWindows in an embedded system environment.
◆ uid_close_queue()
int uid_close_queue ( void  )
Return values
Thismethod returns 0 on success and -1 on error.
◆ uid_open_queue()
int uid_open_queue ( const char *  q_name,
int  flags,
size_t  max_msgs
Parameters
[in]q_nameis the name of the message queue
[in]flagscontrols the behaviour of the queue
[in]max_msgsspecifies the maximum number of pending messages
Note
The message queue is from the Classic API.
Return values
◆ uid_print_message()
void uid_print_message ( struct MW_UID_MESSAGE uid)
Parameters
[in]uidpoints to the message to print
◆ uid_print_message_with_plugin()
void uid_print_message_with_plugin ( void *  context,
Parameters
[in]contextis a pointer to a data area which may be used by some print handlers
[in]handleris the fprintf style method to invoke
◆ uid_read_message()
int uid_read_message ( struct MW_UID_MESSAGE m,
It waits up to the specified timeout in miliseconds. A timeout of 0 is a poll.
Parameters
[in]mwill be filled in with the received message
[in]timeoutis the maximum number of mulliseconds to wait
Return values
◆ uid_send_message()
int uid_send_message ( struct MW_UID_MESSAGE m)
Parameters
[in]mis the message to send
Return values
