Files | Functions
Conversion Helpers
Convert String to Pointer (with validation) More...
file  stringtodouble.c
 Convert String to Double (with validation)
file  stringtofloat.c
 Convert String to Float (with validation)
file  stringtoint.c
 Convert String to Int (with validation)
file  stringtolong.c
 Convert String to Long (with validation)
file  stringtolongdouble.c
 Convert String to long double (with validation)
file  stringtolonglong.c
 Convert String to Long Long (with validation)
file  stringtopointer.c
file  stringtounsignedchar.c
 Convert String to Unsigned Character (with validation)
file  stringtounsignedint.c
 Convert String to Unsigned Int (with validation)
file  stringtounsignedlong.c
 Convert String to Unsigned Long Long (with validation)
file  stringtounsignedlonglong.c
rtems_status_code rtems_string_to_pointer (const char *s, void **n, char **endptr)
 Convert String to Pointer (with validation). More...
rtems_status_code rtems_string_to_unsigned_char (const char *s, unsigned char *n, char **endptr, int base)
 Convert String to Unsigned Character (with validation). More...
rtems_status_code rtems_string_to_int (const char *s, int *n, char **endptr, int base)
 Convert String to Int (with validation). More...
rtems_status_code rtems_string_to_unsigned_int (const char *s, unsigned int *n, char **endptr, int base)
 Convert String to Unsigned Int (with validation). More...
rtems_status_code rtems_string_to_long (const char *s, long *n, char **endptr, int base)
 Convert String to Long (with validation). More...
rtems_status_code rtems_string_to_unsigned_long (const char *s, unsigned long *n, char **endptr, int base)
 Convert String to Unsigned Long (with validation). More...
rtems_status_code rtems_string_to_long_long (const char *s, long long *n, char **endptr, int base)
 Convert String to Long Long (with validation). More...
rtems_status_code rtems_string_to_unsigned_long_long (const char *s, unsigned long long *n, char **endptr, int base)
 Convert String to Unsigned Long Long (with validation). More...
rtems_status_code rtems_string_to_float (const char *s, float *n, char **endptr)
 Convert String to Float (with validation). More...
rtems_status_code rtems_string_to_double (const char *s, double *n, char **endptr)
 Convert String to Double (with validation). More...
rtems_status_code rtems_string_to_long_double (const char *s, long double *n, char **endptr)
 Convert String to long double (with validation). More...
This file defines the interface to a set of string conversion helpers.
◆ rtems_string_to_double()
rtems_status_code rtems_string_to_double ( const char *  s,
double *  n,
char **  endptr
This method converts a string to a double with range validation.
Parameters
[in]sis the string to convert
[in]npoints to the variable to place the converted output in
[in]endptris used to keep track of the position in the string
Return values
Thismethod returns RTEMS_SUCCESSFUL on successful conversion and *n is filled in. Otherwise, the status indicates the source of the error.
◆ rtems_string_to_float()
rtems_status_code rtems_string_to_float ( const char *  s,
float *  n,
char **  endptr
This method converts a string to a float with range validation.
Parameters
Return values
◆ rtems_string_to_int()
rtems_status_code rtems_string_to_int ( const char *  s,
int *  n,
char **  endptr,
int  base
This method converts a string to an int with range validation.
Parameters
[in]baseis the expected base of the number
Return values
◆ rtems_string_to_long()
rtems_status_code rtems_string_to_long ( const char *  s,
long *  n,
char **  endptr,
int  base
This method converts a string to a long with range validation.
Parameters
Return values
◆ rtems_string_to_long_double()
rtems_status_code rtems_string_to_long_double ( const char *  s,
long double *  n,
char **  endptr
This method converts a string to a long double with range validation.
Parameters
Return values
◆ rtems_string_to_long_long()
rtems_status_code rtems_string_to_long_long ( const char *  s,
long long *  n,
char **  endptr,
int  base
This method converts a string to a long long with range validation.
Parameters
Return values
◆ rtems_string_to_pointer()
rtems_status_code rtems_string_to_pointer ( const char *  s,
void **  n,
char **  endptr
This method converts a string to a pointer (void *) with basic numeric validation.
Parameters
Return values
◆ rtems_string_to_unsigned_char()
rtems_status_code rtems_string_to_unsigned_char ( const char *  s,
unsigned char *  n,
char **  endptr,
int  base
This method converts a string to an unsigned character with range validation.
Parameters
Return values
◆ rtems_string_to_unsigned_int()
rtems_status_code rtems_string_to_unsigned_int ( const char *  s,
unsigned int *  n,
char **  endptr,
int  base
This method converts a string to an unsigned int with range validation.
Parameters
Return values
◆ rtems_string_to_unsigned_long()
rtems_status_code rtems_string_to_unsigned_long ( const char *  s,
unsigned long *  n,
char **  endptr,
int  base
This method converts a string to an unsigned long with range validation.
Parameters
Return values
◆ rtems_string_to_unsigned_long_long()
rtems_status_code rtems_string_to_unsigned_long_long ( const char *  s,
unsigned long long *  n,
char **  endptr,
int  base
Parameters
Return values
