#define | __need_size_t |
#define | __ATTR_CONST__ __attribute__((__const__)) |
#define | __ATTR_PROGMEM__ __attribute__((__progmem__)) |
#define | __ATTR_PURE__ __attribute__((__pure__)) |
#define | PROGMEM __ATTR_PROGMEM__ |
| | Attribute to use in order to declare an object being located in flash ROM.
#define | PSTR(s) (__extension__({static char __c[] PROGMEM = (s); &__c[0];})) |
| #define | __LPM_classic__(addr) |
| #define | __LPM_enhanced__(addr) |
| #define | __LPM_word_classic__(addr) |
| #define | __LPM_word_enhanced__(addr) |
| #define | __LPM_dword_classic__(addr) |
| #define | __LPM_dword_enhanced__(addr) |
| #define | __LPM_float_classic__(addr) |
| #define | __LPM_float_enhanced__(addr) |
#define | __LPM(addr) __LPM_classic__(addr) |
#define | __LPM_word(addr) __LPM_word_classic__(addr) |
#define | __LPM_dword(addr) __LPM_dword_classic__(addr) |
#define | __LPM_float(addr) __LPM_float_classic__(addr) |
| #define | pgm_read_byte_near(address_short) __LPM((uint16_t)(address_short)) |
| | Read a byte from the program space with a 16-bit (near) address. More...
| #define | pgm_read_word_near(address_short) __LPM_word((uint16_t)(address_short)) |
| | Read a word from the program space with a 16-bit (near) address. More...
| #define | pgm_read_dword_near(address_short) __LPM_dword((uint16_t)(address_short)) |
| | Read a double word from the program space with a 16-bit (near) address. More...
| #define | pgm_read_float_near(address_short) __LPM_float((uint16_t)(address_short)) |
| | Read a float from the program space with a 16-bit (near) address. More...
| #define | pgm_read_byte(address_short) pgm_read_byte_near(address_short) |
| #define | pgm_read_word(address_short) pgm_read_word_near(address_short) |
| #define | pgm_read_dword(address_short) pgm_read_dword_near(address_short) |
| #define | pgm_read_float(address_short) pgm_read_float_near(address_short) |
| #define | PGM_P const prog_char * |
| | Used to declare a variable that is a pointer to a string in program space. More...
| #define | PGM_VOID_P const prog_void * |
| | Used to declare a generic pointer to an object in program space. More...
PGM_VOID_P | memchr_P (PGM_VOID_P, int __val, size_t __len) __ATTR_CONST__ |
int | memcmp_P (const void *, PGM_VOID_P, size_t) __ATTR_PURE__ |
void * | memccpy_P (void *, PGM_VOID_P, int __val, size_t) |
void * | memcpy_P (void *, PGM_VOID_P, size_t) |
void * | memmem_P (const void *, size_t, PGM_VOID_P, size_t) __ATTR_PURE__ |
PGM_VOID_P | memrchr_P (PGM_VOID_P, int __val, size_t __len) __ATTR_CONST__ |
char * | strcat_P (char *, PGM_P) |
PGM_P | strchr_P (PGM_P, int __val) __ATTR_CONST__ |
PGM_P | strchrnul_P (PGM_P, int __val) __ATTR_CONST__ |
int | strcmp_P (const char *, PGM_P) __ATTR_PURE__ |
char * | strcpy_P (char *, PGM_P) |
int | strcasecmp_P (const char *, PGM_P) __ATTR_PURE__ |
char * | strcasestr_P (const char *, PGM_P) __ATTR_PURE__ |
size_t | strcspn_P (const char *__s, PGM_P __reject) __ATTR_PURE__ |
size_t | strlcat_P (char *, PGM_P, size_t) |
size_t | strlcpy_P (char *, PGM_P, size_t) |
size_t | strlen_P (PGM_P) __ATTR_CONST__ |
size_t | strnlen_P (PGM_P, size_t) __ATTR_CONST__ |
int | strncmp_P (const char *, PGM_P, size_t) __ATTR_PURE__ |
int | strncasecmp_P (const char *, PGM_P, size_t) __ATTR_PURE__ |
char * | strncat_P (char *, PGM_P, size_t) |
char * | strncpy_P (char *, PGM_P, size_t) |
char * | strpbrk_P (const char *__s, PGM_P __accept) __ATTR_PURE__ |
PGM_P | strrchr_P (PGM_P, int __val) __ATTR_CONST__ |
char * | strsep_P (char **__sp, PGM_P __delim) |
size_t | strspn_P (const char *__s, PGM_P __accept) __ATTR_PURE__ |
char * | strstr_P (const char *, PGM_P) __ATTR_PURE__ |
char * | strtok_P (char *__s, PGM_P __delim) |
char * | strtok_rP (char *__s, PGM_P __delim, char **__last) |
