Set Errno
Collaboration diagram for Set Errno:
#define rtems_set_errno_and_return_value(_error, _value)   do { errno = ( _error ); return ( _value ); } while ( 0 )
 This is a helper macro which will set the variable errno and return the specified value to the caller. More...
#define rtems_set_errno_and_return_minus_one(_error)   rtems_set_errno_and_return_value( _error, -1 )
 This is a helper macro which will set the variable errno and return -1 to the caller. More...
◆ rtems_set_errno_and_return_minus_one
#define rtems_set_errno_and_return_minus_one (   _error)    rtems_set_errno_and_return_value( _error, -1 )
◆ rtems_set_errno_and_return_value
#define rtems_set_errno_and_return_value (   _error,
  _value
Parameters
[in]_erroris the error code
[in]_valueis the value to return
