Files | Data Structures | Enumerations | Functions
Multiprocessing Support in Region Manager. More...
Collaboration diagram for Region MP Support:
file  regionmp.c
 Region MP Support.
struct  Region_MP_Packet
 The following data structure defines the packet used to perform remote region operations. More...
enum  Region_MP_Remote_operations {
  REGION_MP_ANNOUNCE_CREATE = 0, REGION_MP_ANNOUNCE_DELETE = 1, REGION_MP_EXTRACT_PROXY = 2, REGION_MP_GET_SEGMENT_REQUEST = 3,
  REGION_MP_GET_SEGMENT_RESPONSE = 4, REGION_MP_RETURN_SEGMENT_REQUEST = 5, REGION_MP_RETURN_SEGMENT_RESPONSE = 6
 The following enumerated type defines the list of remote region operations.
void _Region_MP_Send_process_packet (Region_MP_Remote_operations operation, Objects_Id region_id, rtems_name name, Objects_Id proxy_id)
 Region MP Send Process Packet. More...
rtems_status_code _Region_MP_Send_request_packet (Region_MP_Remote_operations operation, Objects_Id region_id, void *segment, intptr_t size, rtems_option option_set, rtems_interval timeout)
 Region MP Send Request Packet. More...
void _Region_MP_Send_response_packet (Region_MP_Remote_operations operation, Objects_Id region_id, Thread_Control *the_thread)
 Region MP Send Response Packet. More...
void _Region_MP_Process_packet (rtems_packet_prefix *the_packet_prefix)
 Region MP Process Packet. More...
void _Region_MP_Send_extract_proxy (void *argument)
 Region MP Send Extract Proxy. More...
Region_MP_Packet_Region_MP_Get_packet (void)
 RegionMP Get Packet. More...
This encapsulates functionality related to the transparent multiprocessing support within the Classic API Region Manager.
This include file contains all the constants and structures associated with the Multiprocessing Support in the Region Manager.
◆ _Region_MP_Get_packet()
Region_MP_Packet* _Region_MP_Get_packet ( void  )
This function is used to obtain a region mp packet.
References _MPCI_Get_packet().
◆ _Region_MP_Process_packet()
void _Region_MP_Process_packet ( rtems_packet_prefix *  the_packet_prefix)
This routine performs the actions specific to this package for the request from another node.
◆ _Region_MP_Send_extract_proxy()
void _Region_MP_Send_extract_proxy ( void *  argument)
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
References _Region_MP_Send_process_packet().
◆ _Region_MP_Send_process_packet()
void _Region_MP_Send_process_packet ( Region_MP_Remote_operations  operation,
rtems_name  name,
Objects_Id  proxy_id
This routine performs a remote procedure call so that a process operation can be performed on another node.
Referenced by _Region_MP_Send_extract_proxy().
◆ _Region_MP_Send_request_packet()
rtems_status_code _Region_MP_Send_request_packet ( Region_MP_Remote_operations  operation,
void *  segment,
intptr_t  size,
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
◆ _Region_MP_Send_response_packet()
void _Region_MP_Send_response_packet ( Region_MP_Remote_operations  operation,
Thread_Control the_thread
This routine performs a remote procedure call so that a directive can be performed on another node.
