Data Structures | Enumerations | Functions
Barrier MP Support
This encapsulates functionality related to the transparent multiprocessing support within the Classic API Barrier Manager. More...
Collaboration diagram for Barrier MP Support:
struct  Barrier_MP_Packet
 The following data structure defines the packet used to perform remote barrier operations. More...
enum  Barrier_MP_Remote_operations {
  BARRIER_MP_ANNOUNCE_CREATE = 0, BARRIER_MP_ANNOUNCE_DELETE = 1, BARRIER_MP_EXTRACT_PROXY = 2, BARRIER_MP_WAIT_REQUEST = 3,
  BARRIER_MP_WAIT_RESPONSE = 4, BARRIER_MP_RELEASE_REQUEST = 5, BARRIER_MP_RELEASE_RESPONSE = 6
 The following enumerated type defines the list of remote barrier operations.
void _Barrier_MP_Send_process_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, rtems_name name, Objects_Id proxy_id)
 _Barrier_MP_Send_process_packet More...
rtems_status_code _Barrier_MP_Send_request_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, rtems_interval timeout)
 _Barrier_MP_Send_request_packet More...
void _Barrier_MP_Send_response_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, Thread_Control *the_thread)
 _Barrier_MP_Send_response_packet More...
void _Barrier_MP_Process_packet (rtems_packet_prefix *the_packet_prefix)
 _Barrier_MP_Process_packet More...
void _Barrier_MP_Send_object_was_deleted (Thread_Control *the_proxy)
 _Barrier_MP_Send_object_was_deleted More...
void _Barrier_MP_Send_extract_proxy (void *argument)
 _Barrier_MP_Send_extract_proxy More...
Barrier_MP_Packet_Barrier_MP_Get_packet (void)
 _Barrier_MP_Get_packet More...
◆ _Barrier_MP_Get_packet()
Barrier_MP_Packet* _Barrier_MP_Get_packet ( void  )
This function is used to obtain a barrier mp packet.
◆ _Barrier_MP_Process_packet()
void _Barrier_MP_Process_packet ( rtems_packet_prefix *  the_packet_prefix)
This routine performs the actions specific to this package for the request from another node.
◆ _Barrier_MP_Send_extract_proxy()
void _Barrier_MP_Send_extract_proxy ( void *  argument)
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
◆ _Barrier_MP_Send_object_was_deleted()
void _Barrier_MP_Send_object_was_deleted ( Thread_Control the_proxy)
This routine is invoked indirectly by the thread queue when a proxy has been removed from the thread queue and the remote node must be informed of this.
◆ _Barrier_MP_Send_process_packet()
void _Barrier_MP_Send_process_packet ( Barrier_MP_Remote_operations  operation,
rtems_name  name,
Objects_Id  proxy_id
This routine performs a remote procedure call so that a process operation can be performed on another node.
◆ _Barrier_MP_Send_request_packet()
rtems_status_code _Barrier_MP_Send_request_packet ( Barrier_MP_Remote_operations  operation,
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
◆ _Barrier_MP_Send_response_packet()
void _Barrier_MP_Send_response_packet ( Barrier_MP_Remote_operations  operation,
Thread_Control the_thread
This routine performs a remote procedure call so that a directive can be performed on another node.
