Files | |
| file | dosfs.h [code] |
| Application Interface to FAT Filesystem. | |
| file | fat.c |
| Low-level Operations on a Volume with a DOSFS FAT filesystem. | |
| file | fat.h [code] |
| Constants/Data Structures/Prototypes on a Volume with FAT Filesystem. | |
| file | fat_fat_operations.c |
| General operations on File Allocation Table. | |
| file | fat_fat_operations.h [code] |
| Constants/Data Structures/Prototypes for Files Allocation Table. | |
| file | fat_file.c |
| General operations on "fat-file". | |
| file | fat_file.h [code] |
| Constants/Data Structures/Prototypes for Operations on "fat-file". | |
| file | msdos.h [code] |
| The MSDOS Filesystem Constants/Data Structures/Prototypes. | |
| file | msdos_conv.c |
| MDOS Date Conversion. | |
| file | msdos_conv_default.c |
| Default Converter. | |
| file | msdos_conv_utf8.c |
| UTF-8 Converter. | |
| file | msdos_create.c |
| Create a new MSDOS FileSystem node. | |
| file | msdos_dir.c |
| MSDOS Directory Handlers Implementation. | |
| file | msdos_eval.c |
| MSDOS Evaluation Routines. | |
| file | msdos_file.c |
| MSDOS File Handlers Implementation. | |
| file | msdos_format.c |
| RTEMS MSDOS Format FunctionalityThis function formats a disk partition conforming to MS-DOS conventions. | |
| file | msdos_free.c |
| Call Fat-File Close Routine. | |
| file | msdos_fsunmount.c |
| Shut Down MSDOS FileSystem. | |
| file | msdos_handlers_dir.c |
| Directory Handlers Table for MSDOS FileSystem. | |
| file | msdos_handlers_file.c |
| File Operations Table for MSDOS FileSystem. | |
| file | msdos_init.c |
| Init Routine for MSDOS. | |
| file | msdos_initsupp.c |
| MSDOS Filesystem Initialization. | |
| file | msdos_misc.c |
| Miscellaneous Routines Implementation for MSDOS FileSystem. | |
| file | msdos_mknod.c |
| Routine for Node Creation in MSDOS Filesystem. | |
| file | msdos_rename.c |
| Rename a MSDOS FileSystem Node. | |
| file | msdos_rmnod.c |
| Remove Node from MSDOS Directory. | |
| file | msdos_statvfs.c |
| Obtain MS-DOS filesystem information. | |
