Stack Overflow Check User Extension SetNOTE: This extension set automatically determines at initialization time whether the stack for this CPU grows up or down and installs the correct extension routines for that direction. More...
#include <inttypes.h>
#include <rtems/bspIo.h>
#include <rtems/stackchk.h>
#include "internal.h"
#define | DONT_USE_FATAL_EXTENSION |
#define | Stack_check_Get_pattern(_the_stack) |
#define | Stack_check_Calculate_used(_low, _size, _high_water) ((char *)(_high_water) - (char *)(_low)) |
#define | Stack_check_usable_stack_start(_the_stack) ((_the_stack)->area) |
#define | Stack_check_Get_pattern_area(_the_stack) (Stack_check_Control *) Stack_check_Get_pattern( _the_stack ) |
#define | Stack_check_usable_stack_size(_the_stack) ((_the_stack)->size - sizeof(Stack_check_Control)) |
#define | Stack_check_Dope_stack(_stack) memset((_stack)->area, BYTE_PATTERN, (_stack)->size) |
bool | rtems_stack_checker_create_extension (Thread_Control *running, Thread_Control *the_thread) |
Stack Checker Task Create Extension. More... | |
void | rtems_stack_checker_begin_extension (Thread_Control *the_thread) |
Stack Checker Task Begin Extension. More... | |
void | Stack_check_report_blown_task (Thread_Control *running, bool pattern_ok) |
void | rtems_stack_checker_switch_extension (Thread_Control *running, Thread_Control *heir) |
Stack Checker Task Context Switch Extension. More... | |
bool | rtems_stack_checker_is_blown (void) |
Checks if current task is blown its stack. More... | |
void | rtems_stack_checker_report_usage_with_plugin (void *context, rtems_printk_plugin_t print) |
Print the stack usage report using caller's routine. More... | |
void | rtems_stack_checker_report_usage (void) |
Print the stack usage report using printk. More... | |
Stack_check_Control | Stack_check_Pattern |
Stack_Control | Stack_check_Interrupt_stack |
#define Stack_check_Get_pattern | ( | _the_stack | ) |
