Chain Handler API. More...
| #define | CHAIN_INITIALIZER_EMPTY(name) { { { &(name).Tail.Node, NULL }, &(name).Head.Node } } |
| Chain initializer for an empty chain with designator name. | |
| #define | CHAIN_INITIALIZER_ONE_NODE(node) { { { (node), NULL }, (node) } } |
| Chain initializer for a chain with one node. More... | |
| #define | CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain) { &(chain)->Tail.Node, &(chain)->Head.Node } |
| Chain node initializer for a chain containing exactly this node. More... | |
| #define | CHAIN_DEFINE_EMPTY(name) Chain_Control name = CHAIN_INITIALIZER_EMPTY(name) |
| Chain definition for an empty chain with designator name. | |
Typedefs | |
| typedef bool(* | Chain_Node_order) (const Chain_Node *left, const Chain_Node *right) |
| Chain node order. More... | |
| void | _Chain_Initialize (Chain_Control *the_chain, void *starting_address, size_t number_nodes, size_t node_size) |
| Initialize a chain header. More... | |
| void | _Chain_Extract (Chain_Node *the_node) |
| Extract the specified node from a chain. More... | |
| Chain_Node * | _Chain_Get (Chain_Control *the_chain) |
| Obtain the first node on a chain. More... | |
| void | _Chain_Insert (Chain_Node *after_node, Chain_Node *the_node) |
| Insert a node on a chain. More... | |
| void | _Chain_Append (Chain_Control *the_chain, Chain_Node *the_node) |
| Append a node on the end of a chain. More... | |
| bool | _Chain_Append_with_empty_check (Chain_Control *the_chain, Chain_Node *the_node) |
| Append a node and check if the chain was empty before. More... | |
| bool | _Chain_Prepend_with_empty_check (Chain_Control *the_chain, Chain_Node *the_node) |
| Prepend a node and check if the chain was empty before. More... | |
| bool | _Chain_Get_with_empty_check (Chain_Control *the_chain, Chain_Node **the_node) |
| Get the first node and check if the chain is empty afterwards. More... | |
| size_t | _Chain_Node_count_unprotected (const Chain_Control *chain) |
| Returns the node count of the chain. More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Set_off_chain (Chain_Node *node) |
| Set off chain. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_node_off_chain (const Chain_Node *node) |
| Is the node off chain. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Are_nodes_equal (const Chain_Node *left, const Chain_Node *right) |
| Are two nodes equal. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_null_node (const Chain_Node *the_node) |
| Is the chain node pointer NULL. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Head (Chain_Control *the_chain) |
| Return pointer to chain head. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_head (const Chain_Control *the_chain) |
| Return pointer to immutable chain head. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Tail (Chain_Control *the_chain) |
| Return pointer to chain tail. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_tail (const Chain_Control *the_chain) |
| Return pointer to immutable chain tail. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_First (Chain_Control *the_chain) |
| Return pointer to chain's first node. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_first (const Chain_Control *the_chain) |
| Return pointer to immutable chain's first node. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Last (Chain_Control *the_chain) |
| Return pointer to chain's last node. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_last (const Chain_Control *the_chain) |
| Return pointer to immutable chain's last node. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Next (Chain_Node *the_node) |
| Return pointer the next node from this node. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_next (const Chain_Node *the_node) |
| Return pointer the immutable next node from this node. More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Previous (Chain_Node *the_node) |
| Return pointer the previous node from this node. More... | |
| RTEMS_INLINE_ROUTINE const Chain_Node * | _Chain_Immutable_previous (const Chain_Node *the_node) |
| Return pointer the immutable previous node from this node. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_empty (const Chain_Control *the_chain) |
| Is the chain empty. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_first (const Chain_Node *the_node) |
| Is this the first node on the chain. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_last (const Chain_Node *the_node) |
| Is this the last node on the chain. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Has_only_one_node (const Chain_Control *the_chain) |
| Does this chain have only one node. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_head (const Chain_Control *the_chain, const Chain_Node *the_node) |
| Is this node the chain head. More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Is_tail (const Chain_Control *the_chain, const Chain_Node *the_node) |
| Is this node the chail tail. More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Initialize_empty (Chain_Control *the_chain) |
| Initialize this chain as empty. More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Extract_unprotected (Chain_Node *the_node) |
| Extract this node (unprotected). More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Get_first_unprotected (Chain_Control *the_chain) |
| Get the first node (unprotected). More... | |
| RTEMS_INLINE_ROUTINE Chain_Node * | _Chain_Get_unprotected (Chain_Control *the_chain) |
| RTEMS_INLINE_ROUTINE void | _Chain_Insert_unprotected (Chain_Node *after_node, Chain_Node *the_node) |
| Insert a node (unprotected). More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Append_unprotected (Chain_Control *the_chain, Chain_Node *the_node) |
| Append a node (unprotected). More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Append_if_is_off_chain_unprotected (Chain_Control *the_chain, Chain_Node *the_node) |
| Append a node on the end of a chain if the node is in the off chain state (unprotected). More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Prepend_unprotected (Chain_Control *the_chain, Chain_Node *the_node) |
| Prepend a node (unprotected). More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Prepend (Chain_Control *the_chain, Chain_Node *the_node) |
| Prepend a node (protected). More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Append_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node *the_node) |
| Append a node and check if the chain was empty before (unprotected). More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Prepend_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node *the_node) |
| Prepend a node and check if the chain was empty before (unprotected). More... | |
| RTEMS_INLINE_ROUTINE bool | _Chain_Get_with_empty_check_unprotected (Chain_Control *the_chain, Chain_Node **the_node) |
| Get the first node and check if the chain is empty afterwards (unprotected). More... | |
| RTEMS_INLINE_ROUTINE void | _Chain_Insert_ordered_unprotected (Chain_Control *chain, Chain_Node *to_insert, Chain_Node_order order) |
| Inserts a node into the chain according to the order relation. More... | |
Chain Handler API.
