armv7m.h
1
7 /*
8  * Copyright (c) 2011-2014 Sebastian Huber. All rights reserved.
9  *
10  * embedded brains GmbH
11  * Obere Lagerstr. 30
12  * 82178 Puchheim
13  * Germany
14  * <rtems@embedded-brains.de>
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef RTEMS_SCORE_ARMV7M_H
22 #define RTEMS_SCORE_ARMV7M_H
23
24 #include <rtems/score/cpu.h>
25
26 #ifdef __cplusplus
27 extern "C" {
28 #endif /* __cplusplus */
29
30 #ifdef ARM_MULTILIB_ARCH_V7M
31
32 /* Coprocessor Access Control Register, CPACR */
33 #define ARMV7M_CPACR 0xe000ed88
34
35 #ifndef ASM
36
37 typedef struct {
38  uint32_t reserved_0;
39  uint32_t ictr;
40  uint32_t actlr;
41  uint32_t reserved_1;
42 } ARMV7M_ICTAC;
43
44 typedef void (*ARMV7M_Exception_handler)(void);
45
46 typedef struct {
47  uint32_t register_r0;
48  uint32_t register_r1;
49  uint32_t register_r2;
50  uint32_t register_r3;
51  uint32_t register_r12;
52  void *register_lr;
53  void *register_pc;
54  uint32_t register_xpsr;
55 #ifdef ARM_MULTILIB_VFP
56  uint32_t register_s0;
57  uint32_t register_s1;
58  uint32_t register_s2;
59  uint32_t register_s3;
60  uint32_t register_s4;
61  uint32_t register_s5;
62  uint32_t register_s6;
63  uint32_t register_s7;
64  uint32_t register_s8;
65  uint32_t register_s9;
66  uint32_t register_s10;
67  uint32_t register_s11;
68  uint32_t register_s12;
69  uint32_t register_s13;
70  uint32_t register_s14;
71  uint32_t register_s15;
72  uint32_t register_fpscr;
73  uint32_t reserved;
74 #endif
75 } ARMV7M_Exception_frame;
76
77 typedef struct {
78  uint32_t cpuid;
79
80 #define ARMV7M_SCB_ICSR_NMIPENDSET (1U << 31)
81 #define ARMV7M_SCB_ICSR_PENDSVSET (1U << 28)
82 #define ARMV7M_SCB_ICSR_PENDSVCLR (1U << 27)
83 #define ARMV7M_SCB_ICSR_PENDSTSET (1U << 26)
84 #define ARMV7M_SCB_ICSR_PENDSTCLR (1U << 25)
85 #define ARMV7M_SCB_ICSR_ISRPREEMPT (1U << 23)
86 #define ARMV7M_SCB_ICSR_ISRPENDING (1U << 22)
87 #define ARMV7M_SCB_ICSR_VECTPENDING_GET(reg) (((reg) >> 12) & 0x1ffU)
88 #define ARMV7M_SCB_ICSR_RETTOBASE (1U << 11)
89 #define ARMV7M_SCB_ICSR_VECTACTIVE_GET(reg) ((reg) & 0x1ffU)
90  uint32_t icsr;
91
92  ARMV7M_Exception_handler *vtor;
93
94 #define ARMV7M_SCB_AIRCR_VECTKEY (0x05fa << 16)
95 #define ARMV7M_SCB_AIRCR_ENDIANESS (1U << 15)
96 #define ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT 8
97 #define ARMV7M_SCB_AIRCR_PRIGROUP_MASK \
98  ((0x7U) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)
99 #define ARMV7M_SCB_AIRCR_PRIGROUP(val) \
100  (((val) << ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK)
101 #define ARMV7M_SCB_AIRCR_PRIGROUP_GET(reg) \
102  (((val) & ARMV7M_SCB_AIRCR_PRIGROUP_MASK) >> ARMV7M_SCB_AIRCR_PRIGROUP_SHIFT)
103 #define ARMV7M_SCB_AIRCR_PRIGROUP_SET(reg, val) \
104  (((reg) & ~ARMV7M_SCB_AIRCR_PRIGROUP_MASK) | ARMV7M_SCB_AIRCR_PRIGROUP(val))
105 #define ARMV7M_SCB_AIRCR_SYSRESETREQ (1U << 2)
106 #define ARMV7M_SCB_AIRCR_VECTCLRACTIVE (1U << 1)
107 #define ARMV7M_SCB_AIRCR_VECTRESET (1U << 0)
108  uint32_t aircr;
109
110  uint32_t scr;
111  uint32_t ccr;
112  uint8_t shpr [12];
113
114 #define ARMV7M_SCB_SHCSR_USGFAULTENA (1U << 18)
115 #define ARMV7M_SCB_SHCSR_BUSFAULTENA (1U << 17)
116 #define ARMV7M_SCB_SHCSR_MEMFAULTENA (1U << 16)
117  uint32_t shcsr;
118
119  uint32_t cfsr;
120  uint32_t hfsr;
121  uint32_t dfsr;
122  uint32_t mmfar;
123  uint32_t bfar;
124  uint32_t afsr;
125  uint32_t reserved_e000ed40[18];
126  uint32_t cpacr;
127  uint32_t reserved_e000ed8c[106];
128  uint32_t fpccr;
129  uint32_t fpcar;
130  uint32_t fpdscr;
131  uint32_t mvfr0;
132  uint32_t mvfr1;
133 } ARMV7M_SCB;
134
135 typedef struct {
136 #define ARMV7M_SYSTICK_CSR_COUNTFLAG (1U << 16)
137 #define ARMV7M_SYSTICK_CSR_CLKSOURCE (1U << 2)
138 #define ARMV7M_SYSTICK_CSR_TICKINT (1U << 1)
139 #define ARMV7M_SYSTICK_CSR_ENABLE (1U << 0)
140  uint32_t csr;
141
142  uint32_t rvr;
143  uint32_t cvr;
144
145 #define ARMV7M_SYSTICK_CALIB_NOREF (1U << 31)
146 #define ARMV7M_SYSTICK_CALIB_SKEW (1U << 30)
147 #define ARMV7M_SYSTICK_CALIB_TENMS_GET(reg) ((reg) & 0xffffffU)
148  uint32_t calib;
149 } ARMV7M_Systick;
150
151 typedef struct {
152  uint32_t iser [8];
153  uint32_t reserved_0 [24];
154  uint32_t icer [8];
155  uint32_t reserved_1 [24];
156  uint32_t ispr [8];
157  uint32_t reserved_2 [24];
158  uint32_t icpr [8];
159  uint32_t reserved_3 [24];
160  uint32_t iabr [8];
161  uint32_t reserved_4 [56];
162  uint8_t ipr [240];
163  uint32_t reserved_5 [644];
164  uint32_t stir;
165 } ARMV7M_NVIC;
166
167 typedef struct {
168 #define ARMV7M_MPU_TYPE_IREGION_GET(reg) (((reg) >> 16) & 0xffU)
169 #define ARMV7M_MPU_TYPE_DREGION_GET(reg) (((reg) >> 8) & 0xffU)
170 #define ARMV7M_MPU_TYPE_SEPARATE (1U << 0)
171  uint32_t type;
172
173 #define ARMV7M_MPU_CTRL_PRIVDEFENA (1U << 2)
174 #define ARMV7M_MPU_CTRL_HFNMIENA (1U << 1)
175 #define ARMV7M_MPU_CTRL_ENABLE (1U << 0)
176  uint32_t ctrl;
177
178  uint32_t rnr;
179
180 #define ARMV7M_MPU_RBAR_ADDR_SHIFT 5
181 #define ARMV7M_MPU_RBAR_ADDR_MASK \
182  ((0x7ffffffU) << ARMV7M_MPU_RBAR_ADDR_SHIFT)
183 #define ARMV7M_MPU_RBAR_ADDR(val) \
184  (((val) << ARMV7M_MPU_RBAR_ADDR_SHIFT) & ARMV7M_MPU_RBAR_ADDR_MASK)
185 #define ARMV7M_MPU_RBAR_ADDR_GET(reg) \
186  (((val) & ARMV7M_MPU_RBAR_ADDR_MASK) >> ARMV7M_MPU_RBAR_ADDR_SHIFT)
187 #define ARMV7M_MPU_RBAR_ADDR_SET(reg, val) \
188  (((reg) & ~ARMV7M_MPU_RBAR_ADDR_MASK) | ARMV7M_MPU_RBAR_ADDR(val))
189 #define ARMV7M_MPU_RBAR_VALID (1U << 4)
190 #define ARMV7M_MPU_RBAR_REGION_SHIFT 0
191 #define ARMV7M_MPU_RBAR_REGION_MASK \
192  ((0xfU) << ARMV7M_MPU_RBAR_REGION_SHIFT)
193 #define ARMV7M_MPU_RBAR_REGION(val) \
194  (((val) << ARMV7M_MPU_RBAR_REGION_SHIFT) & ARMV7M_MPU_RBAR_REGION_MASK)
195 #define ARMV7M_MPU_RBAR_REGION_GET(reg) \
196  (((val) & ARMV7M_MPU_RBAR_REGION_MASK) >> ARMV7M_MPU_RBAR_REGION_SHIFT)
197 #define ARMV7M_MPU_RBAR_REGION_SET(reg, val) \
198  (((reg) & ~ARMV7M_MPU_RBAR_REGION_MASK) | ARMV7M_MPU_RBAR_REGION(val))
199  uint32_t rbar;
200
201 #define ARMV7M_MPU_RASR_XN (1U << 28)
202 #define ARMV7M_MPU_RASR_AP_SHIFT 24
203 #define ARMV7M_MPU_RASR_AP_MASK \
204  ((0x7U) << ARMV7M_MPU_RASR_AP_SHIFT)
205 #define ARMV7M_MPU_RASR_AP(val) \
206  (((val) << ARMV7M_MPU_RASR_AP_SHIFT) & ARMV7M_MPU_RASR_AP_MASK)
207 #define ARMV7M_MPU_RASR_AP_GET(reg) \
208  (((val) & ARMV7M_MPU_RASR_AP_MASK) >> ARMV7M_MPU_RASR_AP_SHIFT)
209 #define ARMV7M_MPU_RASR_AP_SET(reg, val) \
210  (((reg) & ~ARMV7M_MPU_RASR_AP_MASK) | ARMV7M_MPU_RASR_AP(val))
211 #define ARMV7M_MPU_RASR_TEX_SHIFT 19
212 #define ARMV7M_MPU_RASR_TEX_MASK \
213  ((0x7U) << ARMV7M_MPU_RASR_TEX_SHIFT)
214 #define ARMV7M_MPU_RASR_TEX(val) \
215  (((val) << ARMV7M_MPU_RASR_TEX_SHIFT) & ARMV7M_MPU_RASR_TEX_MASK)
216 #define ARMV7M_MPU_RASR_TEX_GET(reg) \
217  (((val) & ARMV7M_MPU_RASR_TEX_MASK) >> ARMV7M_MPU_RASR_TEX_SHIFT)
218 #define ARMV7M_MPU_RASR_TEX_SET(reg, val) \
219  (((reg) & ~ARMV7M_MPU_RASR_TEX_MASK) | ARMV7M_MPU_RASR_TEX(val))
220 #define ARMV7M_MPU_RASR_S (1U << 18)
221 #define ARMV7M_MPU_RASR_C (1U << 17)
222 #define ARMV7M_MPU_RASR_B (1U << 16)
223 #define ARMV7M_MPU_RASR_SRD_SHIFT 8
224 #define ARMV7M_MPU_RASR_SRD_MASK \
225  ((0xffU) << ARMV7M_MPU_RASR_SRD_SHIFT)
226 #define ARMV7M_MPU_RASR_SRD(val) \
227  (((val) << ARMV7M_MPU_RASR_SRD_SHIFT) & ARMV7M_MPU_RASR_SRD_MASK)
228 #define ARMV7M_MPU_RASR_SRD_GET(reg) \
229  (((val) & ARMV7M_MPU_RASR_SRD_MASK) >> ARMV7M_MPU_RASR_SRD_SHIFT)
230 #define ARMV7M_MPU_RASR_SRD_SET(reg, val) \
231  (((reg) & ~ARMV7M_MPU_RASR_SRD_MASK) | ARMV7M_MPU_RASR_SRD(val))
232 #define ARMV7M_MPU_RASR_SIZE_SHIFT 1
233 #define ARMV7M_MPU_RASR_SIZE_MASK \
234  ((0x1fU) << ARMV7M_MPU_RASR_SIZE_SHIFT)
235 #define ARMV7M_MPU_RASR_SIZE(val) \
236  (((val) << ARMV7M_MPU_RASR_SIZE_SHIFT) & ARMV7M_MPU_RASR_SIZE_MASK)
237 #define ARMV7M_MPU_RASR_SIZE_GET(reg) \
238  (((val) & ARMV7M_MPU_RASR_SIZE_MASK) >> ARMV7M_MPU_RASR_SIZE_SHIFT)
239 #define ARMV7M_MPU_RASR_SIZE_SET(reg, val) \
240  (((reg) & ~ARMV7M_MPU_RASR_SIZE_MASK) | ARMV7M_MPU_RASR_SIZE(val))
241 #define ARMV7M_MPU_RASR_ENABLE (1U << 0)
242  uint32_t rasr;
243
244  uint32_t rbar_a1;
245  uint32_t rasr_a1;
246  uint32_t rbar_a2;
247  uint32_t rasr_a2;
248  uint32_t rbar_a3;
249  uint32_t rasr_a3;
250 } ARMV7M_MPU;
251
252 typedef enum {
253  ARMV7M_MPU_AP_PRIV_NO_USER_NO,
254  ARMV7M_MPU_AP_PRIV_RW_USER_NO,
255  ARMV7M_MPU_AP_PRIV_RW_USER_RO,
256  ARMV7M_MPU_AP_PRIV_RW_USER_RW,
257  ARMV7M_MPU_AP_PRIV_RO_USER_NO = 0x5,
258  ARMV7M_MPU_AP_PRIV_RO_USER_RO,
259 } ARMV7M_MPU_Access_permissions;
260
261 typedef enum {
262  ARMV7M_MPU_ATTR_R = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
263  | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN,
264  ARMV7M_MPU_ATTR_RW = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
265  | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_XN | ARMV7M_MPU_RASR_B,
266  ARMV7M_MPU_ATTR_RWX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
267  | ARMV7M_MPU_RASR_C | ARMV7M_MPU_RASR_B,
268  ARMV7M_MPU_ATTR_X = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_NO_USER_NO)
269  | ARMV7M_MPU_RASR_C,
270  ARMV7M_MPU_ATTR_RX = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RO_USER_NO)
271  | ARMV7M_MPU_RASR_C,
272  ARMV7M_MPU_ATTR_IO = ARMV7M_MPU_RASR_AP(ARMV7M_MPU_AP_PRIV_RW_USER_NO)
273  | ARMV7M_MPU_RASR_XN,
274 } ARMV7M_MPU_Attributes;
275
276 typedef enum {
277  ARMV7M_MPU_SIZE_32_B = 0x4,
278  ARMV7M_MPU_SIZE_64_B,
279  ARMV7M_MPU_SIZE_128_B,
280  ARMV7M_MPU_SIZE_256_B,
281  ARMV7M_MPU_SIZE_512_B,
282  ARMV7M_MPU_SIZE_1_KB,
283  ARMV7M_MPU_SIZE_2_KB,
284  ARMV7M_MPU_SIZE_4_KB,
285  ARMV7M_MPU_SIZE_8_KB,
286  ARMV7M_MPU_SIZE_16_KB,
287  ARMV7M_MPU_SIZE_32_KB,
288  ARMV7M_MPU_SIZE_64_KB,
289  ARMV7M_MPU_SIZE_128_KB,
290  ARMV7M_MPU_SIZE_256_KB,
291  ARMV7M_MPU_SIZE_512_KB,
292  ARMV7M_MPU_SIZE_1_MB,
293  ARMV7M_MPU_SIZE_2_MB,
294  ARMV7M_MPU_SIZE_4_MB,
295  ARMV7M_MPU_SIZE_8_MB,
296  ARMV7M_MPU_SIZE_16_MB,
297  ARMV7M_MPU_SIZE_32_MB,
298  ARMV7M_MPU_SIZE_64_MB,
299  ARMV7M_MPU_SIZE_128_MB,
300  ARMV7M_MPU_SIZE_256_MB,
301  ARMV7M_MPU_SIZE_512_MB,
302  ARMV7M_MPU_SIZE_1_GB,
303  ARMV7M_MPU_SIZE_2_GB,
304  ARMV7M_MPU_SIZE_4_GB
305 } ARMV7M_MPU_Size;
306
307 typedef struct {
308  uint32_t rbar;
309  uint32_t rasr;
310 } ARMV7M_MPU_Region;
311
312 #define ARMV7M_MPU_REGION_INITIALIZER(idx, addr, size, attr) \
313  { \
314  ((addr) & ARMV7M_MPU_RBAR_ADDR_MASK) \
315  | ARMV7M_MPU_RBAR_VALID \
316  | ARMV7M_MPU_RBAR_REGION(idx), \
317  ARMV7M_MPU_RASR_SIZE(size) | (attr) | ARMV7M_MPU_RASR_ENABLE \
318  }
319
320 #define ARMV7M_MPU_REGION_DISABLED_INITIALIZER(idx) \
321  { \
322  ARMV7M_MPU_RBAR_VALID | ARMV7M_MPU_RBAR_REGION(idx), \
323  0 \
324  }
325
326 #define ARMV7M_SCS_BASE 0xe000e000
327 #define ARMV7M_ICTAC_BASE (ARMV7M_SCS_BASE + 0x0)
328 #define ARMV7M_SYSTICK_BASE (ARMV7M_SCS_BASE + 0x10)
329 #define ARMV7M_NVIC_BASE (ARMV7M_SCS_BASE + 0x100)
330 #define ARMV7M_SCB_BASE (ARMV7M_SCS_BASE + 0xd00)
331 #define ARMV7M_MPU_BASE (ARMV7M_SCS_BASE + 0xd90)
332
333 #define _ARMV7M_ICTAC \
334  ((volatile ARMV7M_ICTAC *) ARMV7M_ICTAC_BASE)
335 #define _ARMV7M_SCB \
336  ((volatile ARMV7M_SCB *) ARMV7M_SCB_BASE)
337 #define _ARMV7M_Systick \
338  ((volatile ARMV7M_Systick *) ARMV7M_SYSTICK_BASE)
339 #define _ARMV7M_NVIC \
340  ((volatile ARMV7M_NVIC *) ARMV7M_NVIC_BASE)
341 #define _ARMV7M_MPU \
342  ((volatile ARMV7M_MPU *) ARMV7M_MPU_BASE)
343
344 #define ARMV7M_VECTOR_MSP 0
345 #define ARMV7M_VECTOR_RESET 1
346 #define ARMV7M_VECTOR_NMI 2
347 #define ARMV7M_VECTOR_HARD_FAULT 3
348 #define ARMV7M_VECTOR_MEM_MANAGE 4
349 #define ARMV7M_VECTOR_BUS_FAULT 5
350 #define ARMV7M_VECTOR_USAGE_FAULT 6
351 #define ARMV7M_VECTOR_SVC 11
352 #define ARMV7M_VECTOR_DEBUG_MONITOR 12
353 #define ARMV7M_VECTOR_PENDSV 14
354 #define ARMV7M_VECTOR_SYSTICK 15
355 #define ARMV7M_VECTOR_IRQ(n) ((n) + 16)
356 #define ARMV7M_IRQ_OF_VECTOR(n) ((n) - 16)
357
358 #define ARMV7M_EXCEPTION_PRIORITY_LOWEST 255
359
360 static inline bool _ARMV7M_Is_vector_an_irq( int vector )
361 {
362  return vector >= 16;
363 }
364
365 static inline uint32_t _ARMV7M_Get_basepri(void)
366 {
367  uint32_t val;
368  __asm__ volatile ("mrs %[val], basepri\n" : [val] "=&r" (val));
369  return val;
370 }
371
372 static inline void _ARMV7M_Set_basepri(uint32_t val)
373 {
374  __asm__ volatile ("msr basepri, %[val]\n" : : [val] "r" (val));
375 }
376
377 static inline uint32_t _ARMV7M_Get_primask(void)
378 {
379  uint32_t val;
380  __asm__ volatile ("mrs %[val], primask\n" : [val] "=&r" (val));
381  return val;
382 }
383
384 static inline void _ARMV7M_Set_primask(uint32_t val)
385 {
386  __asm__ volatile ("msr primask, %[val]\n" : : [val] "r" (val));
387 }
388
389 static inline uint32_t _ARMV7M_Get_faultmask(void)
390 {
391  uint32_t val;
392  __asm__ volatile ("mrs %[val], faultmask\n" : [val] "=&r" (val));
393  return val;
394 }
395
396 static inline void _ARMV7M_Set_faultmask(uint32_t val)
397 {
398  __asm__ volatile ("msr faultmask, %[val]\n" : : [val] "r" (val));
399 }
400
401 static inline uint32_t _ARMV7M_Get_control(void)
402 {
403  uint32_t val;
404  __asm__ volatile ("mrs %[val], control\n" : [val] "=&r" (val));
405  return val;
406 }
407
408 static inline void _ARMV7M_Set_control(uint32_t val)
409 {
410  __asm__ volatile ("msr control, %[val]\n" : : [val] "r" (val));
411 }
412
413 static inline uint32_t _ARMV7M_Get_MSP(void)
414 {
415  uint32_t val;
416  __asm__ volatile ("mrs %[val], msp\n" : [val] "=&r" (val));
417  return val;
418 }
419
420 static inline void _ARMV7M_Set_MSP(uint32_t val)
421 {
422  __asm__ volatile ("msr msp, %[val]\n" : : [val] "r" (val));
423 }
424
425 static inline uint32_t _ARMV7M_Get_PSP(void)
426 {
427  uint32_t val;
428  __asm__ volatile ("mrs %[val], psp\n" : [val] "=&r" (val));
429  return val;
430 }
431
432 static inline void _ARMV7M_Set_PSP(uint32_t val)
433 {
434  __asm__ volatile ("msr psp, %[val]\n" : : [val] "r" (val));
435 }
436
437 static inline uint32_t _ARMV7M_Get_XPSR(void)
438 {
439  uint32_t val;
440  __asm__ volatile ("mrs %[val], xpsr\n" : [val] "=&r" (val));
441  return val;
442 }
443
444 static inline bool _ARMV7M_NVIC_Is_enabled( int irq )
445 {
446  int index = irq >> 5;
447  uint32_t bit = 1U << (irq & 0x1f);
448
449  return (_ARMV7M_NVIC->iser [index] & bit) != 0;
450 }
451
452 static inline void _ARMV7M_NVIC_Set_enable( int irq )
453 {
454  int index = irq >> 5;
455  uint32_t bit = 1U << (irq & 0x1f);
456
457  _ARMV7M_NVIC->iser [index] = bit;
458 }
459
460 static inline void _ARMV7M_NVIC_Clear_enable( int irq )
461 {
462  int index = irq >> 5;
463  uint32_t bit = 1U << (irq & 0x1f);
464
465  _ARMV7M_NVIC->icer [index] = bit;
466 }
467
468 static inline bool _ARMV7M_NVIC_Is_pending( int irq )
469 {
470  int index = irq >> 5;
471  uint32_t bit = 1U << (irq & 0x1f);
472
473  return (_ARMV7M_NVIC->ispr [index] & bit) != 0;
474 }
475
476 static inline void _ARMV7M_NVIC_Set_pending( int irq )
477 {
478  int index = irq >> 5;
479  uint32_t bit = 1U << (irq & 0x1f);
480
481  _ARMV7M_NVIC->ispr [index] = bit;
482 }
483
484 static inline void _ARMV7M_NVIC_Clear_pending( int irq )
485 {
486  int index = irq >> 5;
487  uint32_t bit = 1U << (irq & 0x1f);
488
489  _ARMV7M_NVIC->icpr [index] = bit;
490 }
491
492 static inline bool _ARMV7M_NVIC_Is_active( int irq )
493 {
494  int index = irq >> 5;
495  uint32_t bit = 1U << (irq & 0x1f);
496
497  return (_ARMV7M_NVIC->iabr [index] & bit) != 0;
498 }
499
500 static inline void _ARMV7M_NVIC_Set_priority( int irq, int priority )
501 {
502  _ARMV7M_NVIC->ipr [irq] = (uint8_t) priority;
503 }
504
505 static inline int _ARMV7M_NVIC_Get_priority( int irq )
506 {
507  return _ARMV7M_NVIC->ipr [irq];
508 }
509
510 int _ARMV7M_Get_exception_priority( int vector );
511
512 void _ARMV7M_Set_exception_priority( int vector, int priority );
513
514 ARMV7M_Exception_handler _ARMV7M_Get_exception_handler( int index );
515
516 void _ARMV7M_Set_exception_handler(
517  int index,
518  ARMV7M_Exception_handler handler
519 );
520
524 void _ARMV7M_Set_exception_priority_and_handler(
525  int index,
526  int priority,
527  ARMV7M_Exception_handler handler
528 );
529
530 void _ARMV7M_Exception_default( void );
531
532 void _ARMV7M_Interrupt_service_enter( void );
533
534 void _ARMV7M_Interrupt_service_leave( void );
535
536 void _ARMV7M_Pendable_service_call( void );
537
538 void _ARMV7M_Supervisor_call( void );
539
540 #endif /* ASM */
541
542 #endif /* ARM_MULTILIB_ARCH_V7M */
543
544 #ifdef __cplusplus
545 }
546 #endif /* __cplusplus */
547
548 #endif /* RTEMS_SCORE_ARMV7M_H */
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
