Information Required to Manipulate Physical Addresses. More...
#include <rtems/score/cpu.h>
| RTEMS_INLINE_ROUTINE void * | _Addresses_Add_offset (const void *base, uintptr_t offset) |
| Add offset to an address. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Subtract_offset (const void *base, uintptr_t offset) |
| Subtract offset from offset. More... | |
| RTEMS_INLINE_ROUTINE int32_t | _Addresses_Subtract (const void *left, const void *right) |
| Subtract two offsets. More... | |
| RTEMS_INLINE_ROUTINE bool | _Addresses_Is_aligned (const void *address) |
| Is address aligned. More... | |
| RTEMS_INLINE_ROUTINE bool | _Addresses_Is_in_range (const void *address, const void *base, const void *limit) |
| Is address in range. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Align_up (void *address, size_t alignment) |
| Align address to nearest multiple of alignment, rounding up. More... | |
| RTEMS_INLINE_ROUTINE void * | _Addresses_Align_down (void *address, size_t alignment) |
| Align address to nearest multiple of alignment, truncating. More... | |
This include file contains the information required to manipulate physical addresses.
