RTEMS Logo
RTEMS 4.8.1 On-Line Library
I/O Manager IO_LOOKUP_NAME - Lookup a device
16.4.5: IO_LOOKUP_NAME - Lookup a device
CALLING SEQUENCE:
NOT SUPPORTED FROM Ada BINDING
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.UNSATISFIED - name not registered
DESCRIPTION:
This directive returns the major/minor number pair associated with the given device name in device_info.
NOTES:
This directive will not cause the calling task to be preempted.
Copyright © 1988-2007OAR Corporation
