RTEMS Logo
RTEMS 4.8.1 On-Line Library
I/O Manager IO_REGISTER_NAME - Register a device
16.4.4: IO_REGISTER_NAME - Register a device
CALLING SEQUENCE:
NOT SUPPORTED FROM Ada BINDING
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.TOO_MANY - too many devices registered
DESCRIPTION:
This directive associates name with the specified major/minor number pair.
NOTES:
This directive will not cause the calling task to be preempted.
Copyright © 1988-2007OAR Corporation
