BSP and Device Driver Development Guide
The Shm_Unlock
routine is responsible for
releasing the lock field and reenabling processor
interrupts. This routines usually is implemented as follows:
void Shm_Unlock( Shm_Locked_queue_Control *lq_cb ) { set the lock to the unlocked value reenable processor interrupts to their level prior to the lock being acquired. This value was saved in the global variable Shm_isrstat }
