BSP and Device Driver Development Guide
The Shm_Lock
routine is responsible for
acquiring the lock field. Interrupts should be
disabled while that lock is acquired. If the lock
is currently unavailble, then the locking routine
should delay a few microseconds to allow the other
node to release the lock. Doing this reduces bus contention
for the lock. This routines usually is implemented as follows:
void Shm_Lock( Shm_Locked_queue_Control *lq_cb ) { disable processor interrupts set Shm_isrstat to previous interrupt disable level while ( TRUE ) { atomically attempt to acquire the lock if the lock was acquired return delay some small period of time } }
