RTEMS Logo
RTEMS 4.7.0 On-Line Library
Intel/AMD x86 Specific Information Interrupt Stack
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
2.4.5: Interrupt Stack
The i386 family does not support a dedicated hardware interrupt stack. On this processor, RTEMS allocates and manages a dedicated interrupt stack. As part of vectoring a non-nested interrupt service routine, RTEMS switches from the stack of the interrupted task to a dedicated interrupt stack. When a non-nested interrupt returns, RTEMS switches back to the stack of the interrupted stack. The current stack pointer is not altered by RTEMS on nested interrupt.
Without a dedicated interrupt stack, every task in the system MUST have enough stack space to accommodate the worst case stack usage of that particular task and the interrupt service routines COMBINED. By supporting a dedicated interrupt stack, RTEMS significantly lowers the stack requirements for each task.
RTEMS allocates the dedicated interrupt stack from the Workspace Area. The amount of memory allocated for the interrupt stack is determined by the interrupt_stack_size field in the CPU Configuration Table.
