RTEMS Logo
RTEMS 4.6.0 On-Line Library
Getting Started Attaching To The System
PREV UP NEXT Bookshelf RTEMS/GDB User's Guide
3.3: Attaching To The System
The entire target system is viewed as a single multi-threaded process, the identifier of which is 1. To attach, use:
(gdb) attach 1
When successfully attached, the user can control the execution of the target system from the debugger.
