RTEMS Logo
RTEMS 4.6.0 On-Line Library
Getting Started Starting a debugging session
PREV UP NEXT Bookshelf RTEMS/GDB User's Guide
3.2: Starting a debugging session
After having launched GDB, the user must connect to the RTEMS target with the following commands:
(gdb) setrpcmode sun
(gdb) setdaemontype rdbg
(gdb) target rtems target-name
Then he can use the file GDB command to specify the binary to be debugged.
This initialization phase can be written in a ``.gdbinit'' file. Each time, the user will launch GDB, it will execute this initialization sequence.
