RTEMS Logo
RTEMS 4.6.0 On-Line Library
Input and Output Primitives Manager close - Closes a file.
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
5.4.4: close - Closes a file.
CALLING SEQUENCE:
#include <unistd.h>
int close(
  int fildes
STATUS CODES:
EBADF
Invalid file descriptor
EINTR
Function was interrupted by a signal.
DESCRIPTION:
The close() function deallocates the file descriptor named by fildes and makes it available for reuse. All outstanding record locks owned by this process for the file are unlocked.
NOTES:
A signal can interrupt the close() function. In that case, close() returns -1 with errno set to EINTR. The file may or may not be closed.
