Input and Output Primitives Manager dup2 - Duplicates an open file descriptor
RTEMS POSIX API User's Guide
5.4.3: dup2 - Duplicates an open file descriptor
CALLING SEQUENCE:
#include <unistd.h>
int dup2(
int fildes,
int fildes2
STATUS CODES:
EBADF
Invalid file descriptor.
EINTR
Function was interrupted by a signal.
EMFILE
The process already has the maximum number of file descriptors open
and tried to open a new one.
DESCRIPTION:
Dup2 creates a copy of the file descriptor oldfd.
The old and new descriptors may be used interchangeably. They share locks, file
position pointers and flags; for example, if the file position is modified by using
lseek on one of the descriptors, the position is also changed for the other.
